Print PDF report for web which is hos on azure web app server is slow
Posted by: huynhduyhaiduacc on 21 August 2018, 1:16 am EST
  • Posted 21 August 2018, 1:16 am EST
    We are using Active RP v9 document for print a PDF report which has 116 pages and around ~800 kb.
    When it runs on localhost take 10 seconds, but when I deploy to Azure host it takes more than 40 seconds it means 4 times slowly.
    An azure host is standard S1, and a file size just 800kb so I think this is not a cause.
    Is there any way to get around this?
    Any other ideas or solutions would be GREATLY appreciated!!!
  • Posted 21 August 2018, 6:48 am EST
    If my understanding is correct, you are using “AcrobatReader” viewer type of “WebViewer” and hosted the application to the Azure server. After that, you are printing the report using the acrobat printer button.
    Please confirm If my understanding is correct?
  • Posted 27 August 2018, 2:37 am EST
    Hi mohitg
    Thanks for your response
    I write a binary to response and let browser open it by default.
    My code struct is below:
    MainPge.aspx
    Sub PrintPdf()
    	Dim pdfstream() As Byte
                pdfstream = ReportDll.MakePdf()
    	Response.BinaryWrite(pdfstream )
    End Sub
    ReportDll
    Funcntion MakePdf() As Byte()
    _pdf = New Section.PdfExport
    memStream = New System.IO.MemoryStream
    _pdf.Export(_rpt3.Document, memStream)
    Return memStream.ToArray()
    End Function
    And when it prints a report, it takes 100% CPU usage.
    Thanks!
  • Posted 27 August 2018, 3:01 am EST
  • Posted 27 August 2018, 7:50 am EST
    Could you please confirm which version of AR that you are using AR9 or AR12.
  • Posted 28 August 2018, 12:32 am EST
    I am using AR9.0J Professional
  • Posted 28 August 2018, 5:54 am EST
    Could you please check with the latest version of AR as there are lots of performance issue resolved in the latest version.
  • Posted 29 August 2018, 3:42 am EST
    Hi Mohit
    Can I upgrade from AR9 → AR12 at no additional cost or I have to purchase a new version separately
  • Posted 29 August 2018, 4:40 am EST
    You need to purchase the new version separately. However, you could check with the trial version of AR12. If the issue still reproducible with the new version of AR then could you please share the sample application with us so that I can replicate the issue at my end.
    If the issue is not reproducible in the new version of AR then I would request to upgrade the AR to the latest build.
