Posted 13 September 2018, 1:37 pm EST
How to print a MVC report page?
Posted by: marcelo on 13 September 2018, 1:37 pm EST
Posted 13 September 2018, 11:45 pm EST
You can use the Print method of “HTML5” viewer as follow to print the report.
viewer.print()
Also, you can refer to the following documentation link:
http://help.grapecity.com/activereports/webhelp/AR12/webframe.html#HTML5WorkingwithViewerUsingJavascript.html
Posted 14 September 2018, 8:45 pm EST - Updated 30 September 2022, 5:57 pm EST
Posted 14 September 2018, 8:48 pm EST
PS: I’m not using html5 viewer.
Posted 14 September 2018, 8:51 pm EST
PS 2: I’m trying to implement this example
http://help.grapecity.com/activereports/webhelp/AR12/webframe.html#CustomizingHTMLViewer.html
Posted 17 September 2018, 2:38 am EST
Posted 17 September 2018, 7:27 pm EST
Thanks for the sample.
The button appears and make calls to defined action , but when I try to export to PDF, the report is empty.
What I’m doing wrong?
I tried to put it in different actions and in the same action, and in both cases the report returns empty.
I’m using asp mvc with webforms engine not razor engine and using PageReport, not SectionReport.
public ActionResult ReportViewer(bool? print)
if (print ?? false)
//try to use same action. Doesn't work
var rpt = new PageReport();
rpt.Run();
var export = new PdfExport();
var memStream = new MemoryStream();
export.Export(rpt.Document, memStream);
return new System.Web.Mvc.FileStreamResult(memStream, "application/pdf");
var report = default(PageReport);
//some code to load report
ViewBag.Report = report;
return View();
public ActionResult PrintReport()
//or use a different acttion, doesn't work too
rpt.Run();
Posted 18 September 2018, 7:12 am EST
You pageReport object is empty that’s why the report is empty. Could you please try after load the Page Report definition like below:
var rpt = new PageReport(new FileInfo(“Report path”));
Posted 18 September 2018, 7:40 am EST - Updated 30 September 2022, 5:57 pm EST
Hi.
No, It’s Not.
As you can see in the imagem, there is some information on the report.
And below, is my full code to load the report.
At last post was just a simple example, not the full code.
if (print ?? false)
rpt.Run();
var id = Convert.ToInt64(Request.QueryString["id"]);
var reportDefinition = DependencyManager.Resolver.GetService<ReportLoader>().Load(id);
var reportDef = ReportHelper.ConfigureConnection(reportDefinition.Model);
//será usada mais tarde quando o contexto não existir, mas é preciso saber a string de conexão.
var stringCnn = Tenant.Manager.ConnectionString;
Reports.DataProvider.DataProviderFactory.DataProviderService = () => new DataProviderService(stringCnn);
using (var reader = new StringReader(reportDef))
report = new PageReport();
report.Load(reader);
report.ConfigurationProvider = new ConfigurationProvider();
return View();
Posted 19 September 2018, 5:02 am EST
Hello Marcelo,
Please refer the following code
if (print ?? false)
rpt.Run();
You are exporting the rpt object to PDF format which does not contain any report definition that’s why you get the empty pdf.
Hope it clarifies.
Posted 20 September 2018, 12:42 pm EST
Hi.
In example that you sent to me, you create a new one empty too.
The class MyCustomHtmlOutputter is just for create the name and the file with an “empty/or not” report, because in this line Dim rpt As New SectionReport1() you create new and in this line rpt.Run(False) you execute the report, but, from where the report is loaded?
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
If (Request("Task") IsNot Nothing) Then
If (Request("Task").ToString().Contains("Print")) Then
Try
rpt.Run(False)
Catch eRunReport As Exception
'If the report fails to run, report the error to the user
Response.Clear()
Response.Write("<h1>Error running report:</h1>")
Response.Write(eRunReport.ToString())
Return
End Try
'Buffer this page's output until the report output is ready.
Response.Buffer = True
'Clear any part of this page that might have already been buffered for output.
Response.ClearContent()
'Clear any headers that might have already been buffered (such as the content type
'for an HTML page)
Response.ClearHeaders()
'Tell the browser and the "network" that the resulting data of this page should be
'cached since this could be a dynamic report that changes upon each request.
Response.Cache.SetCacheability(HttpCacheability.NoCache)
'Tell the browser this is an Html document so it will use an appropriate viewer.
Response.ContentType = "text/HTML"
'Create the Html export object
Dim HtmlExport1 As New GrapeCity.ActiveReports.Export.Html.Section.HtmlExport()
Dim outputter As New MyCustomHtmlOutputter(Me.Context)
HtmlExport1.Export(rpt.Document, outputter, "")
Response.Redirect("ReportOutput" + "/" + System.IO.Path.GetFileName(outputter.mainPage))
End If
End If
End Sub
Posted 21 September 2018, 3:18 am EST
Hello Marcelo,
“SectionReport1” is “Code-based section report” in which report layouts are saved as C# or Visual Basic files within the project in which they are created. So you don’t need to load the report into object, you can simply create the object of “Code-based section report”. Where as report layout of “PageReport” is saved in “RDLX” format file that’s why you need to load the report definition into “PageReport” class object. For more information, Please refer the following documentation link:
http://help.grapecity.com/activereports/webhelp/AR12/webframe.html#ReportTypes.html
Hope it clarifies.
Posted 21 September 2018, 8:02 am EST
I’m using a page report and load it from a string saved on my database using a [i]StringReader[/in].
The RDLX file do not stay on the client, because I can have a lot of customizations for each tenant.
A workaround I’m thinking about, is print each DIV, but for this, I have to simule the next page click, save the current DIV on the browser memory e so on, and I don’t think is a good ideia.
So, why ActiveReports doesn’t have a builtin printer button for webviewer?
If there a way to get parameters selected by users, I can recreate the report on server side and convert it to pdf and send to browser.
Posted 24 September 2018, 1:34 am EST
Hello Marcelo,
I have updated the sample according to your requirement. You can load the report object the from the WebViewer to Print the Report. Could you please refer to the attached project If it could help you.
Also, could you please confirm are you comfortable to use “HTML5” viewer to have inbuilt Print functionality.
WebApplication5-Modified.zip
Posted 17 October 2018, 1:59 pm EST
Hi.
Sorry for taking long time to get back to this topic. But here I’m again.
I create an example that has the same behavior as I have in my application.
Below is the link to download the example.
In my example, I am not able to print or export to .PDF as well
http://desenvolvedores.net/grapecity/myexample.rar
[edit]
I forgot to say. I’m using NWIND.mdb to create a report sample[/edit]
Posted 18 October 2018, 4:21 am EST
Thanks for the sample application. When clicking on the custom Print button, I got the error ‘The sections collection is invalid’ because the SectionReport doesn’t have any sections. I modified the code and added sections to the report and modified the code to export to Pdf as well, as given below:
var rpt = new SectionReport();
rpt.Sections.Add(new GrapeCity.ActiveReports.SectionReportModel.PageHeader());
rpt.Sections.Add(new GrapeCity.ActiveReports.SectionReportModel.Detail());
rpt.Sections.Add(new GrapeCity.ActiveReports.SectionReportModel.PageFooter());
var txt = new GrapeCity.ActiveReports.SectionReportModel.TextBox
Text = "New TextBox"
rpt.Sections[1].Controls.Add(txt);
rpt.Run(false);
Response.Buffer = true;
Response.ClearContent();
Response.ClearHeaders();
Response.Cache.SetCacheability(HttpCacheability.NoCache);
Response.ContentType = "application/pdf";
Response.AddHeader("content-disposition", "inline");
Response.BinaryWrite(memStream.GetBuffer());
Response.End();
return null;
//return new FileStreamResult(memStream, "application/pdf");
I have attached the modified sample for your reference. You would need to change the db path in the SampleReport.txt back to original and also version info in the Licenses.licx and web.config files.
Hope it helps
Posted 18 October 2018, 10:38 am EST - Updated 30 September 2022, 5:57 pm EST
Posted 22 October 2018, 4:20 am EST
Hi Marcelo,
Since you had created a new object of SectionReport in the PrintReport method in your sample, I provided the code accordingly. Nevertheless, as you’re using the WebViewer control, there is no need to print/export the already shown report from the server. You can use the WebViewer’s client side ViewModel to print and export the displayed report. Here’s the code that you can use:
var viewModel;
$(document).ready(function () {
$(".arvToolBar").append("<span><input id='btnPrint' type='Button' value='Print' onclick='print()'/></span>");
$(".arvToolBar").append("<span><input id='btnExport' type='Button' value='Pdf' onclick='PdfExport()'/></span>");
$('#_wvr').bind('loaded', function () {
viewModel = GetViewModel("_wvr");
function print() {
viewModel.Print();
function PdfExport() {
viewModel.Export(ExportType.Pdf, function (uri) {
window.open(uri);
}, true);
Hope it helps achieve what you’re looking for
Posted 23 October 2018, 12:00 pm EST
Thanks Abdias.
That’s was I really looking for.
