PrintOptions PageScaling
Posted by: c.schuller on 16 February 2022, 9:40 am EST
    Posted 16 February 2022, 9:40 am EST
    Hi there,
    I am using AR14.3 with SectionReport. Our system is generating automatically the PDF report and save the file on the server. Now the report should also print automatically after run. I added the code
    Me.Document.Print(False, False, False)
    on the _ReportEnd. This works also fine, but the Margins are set to 0 so the printer cuts some informations from the top & buttom line. I found a feature named PageScaling and added to the _ReportEnd
    Me.Document.PrintOptions.PageScaling = Extensibility.Printing.PageScaling.FitToPrintableArea
    but nothing happend when the report runs. Is there an other solution or trick to fit the report on the pagesize?
    Thanks in advance.
    Greetings,
    Chris
  • Posted 24 February 2022, 12:00 am EST
    We apologize for the delayed response, You can try updating the Margins within the ReportStart event to ensure that the report gets printed properly. Please refer to the code snippet below:
    private void SectionReport1_ReportStart(object sender, EventArgs e)
                this.PageSettings.Margins= new GrapeCity.ActiveReports.Document.Section.Margins(1, 1, 1, 1);
    You may also refer to the sample application implementing the same below.
    Dushyant Sharma
    SectionReportApplication.zip
  • Posted 31 May 2022, 7:03 am EST
    Dear Sharma,
    I apologize my later answer to your reply. Today I found time to check your solution, but I have to modify the report, because the page was setup for A4. After adding the Margins there is a pagebreak which is not good. I am looking more for a solution during the print with a scaling the page or so. Is there any possibilities there?
    Chris
  • Posted 3 June 2022, 6:57 am EST
    The page break was being introduced because the left and right margins in the above code snippet were causing the report page size to overflow the printer page size, thus introducing empty pages in between. To resolve the same, please try reducing the margins as below:
                this.PageSettings.Margins= new GrapeCity.ActiveReports.Document.Section.Margins(0.5f, 1, 0.5f, 1);
    Furthermore, we can also use PageScaling to scale down the pageSize to PrintableArea using the below code snippet:
    rpt.Document.PrintOptions.PageScaling =
          GrapeCity.ActiveReports.Extensibility.Printing.PageScaling.ShrinkToPrintableArea;
    rpt.Document.Print(true, true, true);
    However, if the issue persists, please provide a sample report depicting the issue so that we could debug it and reply accordingly.
    Dushyant Sharma
