Problems converting version 12 to 14
Posted by: andrewa on 20 May 2021, 12:21 pm EST
  • Posted 20 May 2021, 12:21 pm EST
    After using the conversion tool in VS2019, Tools → Convert To ActiveReports 14, I’m presented with an error at the end of the conversions.
    The type initializer for ‘GrapeCity.ActiveReports.VisualStudio.Internal.*’ threw an exception
    The installer I’m using is the latest version I believe, ActiveReports-v14.2.20458.msi
  • Posted 20 May 2021, 1:53 pm EST
    Can you check with the following build as related issue fixed in the same build
    http://cdn.grapecity.com/ActiveReports/AR14/Hotfixes/ActiveReports-v14.2.20886.msi
  • Posted 20 May 2021, 4:20 pm EST
    Yes thank you, this solved my issue. It is a bit surprising that this version is not listed on the version download history page.
  • Posted 20 May 2021, 11:31 pm EST
    This is a hotfix version. It does not appear on version down load history.
