RDL Report issue after upgrading from AR 10 to AR 12
Posted by: bill on 23 February 2018, 12:48 pm EST
    Posted 23 February 2018, 12:48 pm EST
    We have an issue with Sub Reports inside of a Banded List after we upgraded from Active Reports 10 to Active Reports 12. Only one of two sub-reports is visible when the report is rendered. The other is taking up space, but none the elements of the sub report are visible.
    I was able to create a version of the report that can be tested in the end user report designer. The attached file has three rdlx files - one is for the main report and two are for the sub reports. There is also a backup of a SQL Server 2014 database that has the data. The reports are connected to data in that database. To recreate the issue one would need to edit the database connection information in the Data Sources in each report and it should function. The report runs correctly in AR 10, but one sub report is not rendered in AR 12.
    We would like to know if this is a bug in AR 12 that can be fixed, or if we will have to manually rework any report with a sub report in a banded list if we update to AR 12.
    Thanks in advance for any assistance.
  • Posted 23 February 2018, 12:54 pm EST
    I did upload my attachment with the correct format so here it is as a zip file
    AR12SubbreportIssue.zip
  • Posted 26 February 2018, 12:32 am EST
    It seems that you forget to attach the backup of your database. Could you please share the backup of your database so that we can replicate the issue at our end.
  • Posted 1 March 2018, 9:21 am EST
    Sorry, I thought it was in the zip file. Here it is.ARTest.zip
  • Posted 5 March 2018, 8:22 am EST
    I am able to replicate the issue at my end. I am trying to find the root cause of this different behaviour and will revert you once found any related information for this.
  • Posted 7 March 2018, 9:43 am EST
    We have escalated your issue to our development team(TrackingId: 255275) and will revert you once we got any information from them.
  • Posted 7 March 2018, 11:17 am EST
    Thanks for the update. I’ll keep checking.
  • Posted 15 March 2018, 7:36 am EST
    Any updates n this?
  • Posted 16 March 2018, 12:52 am EST
    I have asked the concerned team about the issue and will update you once I get any information from them.
    Thanks for patience.
  • Posted 13 April 2018, 8:03 am EST
    Any updates on this?
  • Posted 16 April 2018, 2:25 am EST
    The issue you were facing is fixed, however the build is still under testing. We will inform you as soon as the hotfix is available.
  • Posted 19 April 2018, 5:01 am EST
    You can download the hotfix from the following link:
    http://cdn.grapecity.com/ActiveReports/ar12/hotfixes/ActiveReports-v12.1.13124.0.msi
    Hope it resolves your issue.
