Read Codebar problem
Posted by: ricgom731 on 3 July 2019, 10:53 am EST
  • Posted 3 July 2019, 10:53 am EST
    I need to generate a bar code 128 on a 3-inch paper (epson tm t20ii printer).
    When the code is short you can read it well, but the problem I have is that if I print a long code
    As of about 29 characters, the printing of the code is illegible, apparently the code bars are spliced ​​and illegible.
    How can I solve this so that the bars do not fit into a 3-inch-wide paper?
  • Posted 4 July 2019, 1:11 am EST
    Could you please share the barcode size on the 3- inch wide paper. I have tested with an approx 2-inch wide barcode with 29 letters and no issue is observed. Also, are you using the Section or Page/Rdl report?
  • Posted 4 July 2019, 11:26 am EST - Updated 30 September 2022, 5:41 pm EST
    Good day.
    I attach a document in Word.
    On page 1 is an image of the document with the bar code printed on the 3-inch roll (the print was scanned and inserted as an image into Word).
    On page 2 is the same barcode but printed with a laser printer on a letter-sized sheet (the print was scanned and inserted as an image to Word).
    It can be seen that in the image on page 1 some bars are spliced ​​and that is why the code can not be read.
    I printed the Word document that I attach in this message and if I could read the code on page 2 (although it is a bit of a battle because it is an image stuck in Word and loses quality) and the code on page 1 can not be read.
    Attached image with the report design (Section Report (Code Based)).
    I have moved several parameters that are shown in the image as DPI, BarAdjust or Module Size and I can not print the 3-inch roll code correctly.
    I have tried with code Code_128_A and Code_128auto but in both cases if I can read when I print on letter-sized sheet and when I print on 3-inch roll I can not read
    The printer that I use in an epson tm t20ii.
    Please help.
  • Posted 4 July 2019, 11:27 am EST
    Word Docuement
  • Posted 4 July 2019, 11:28 am EST
  • Posted 4 July 2019, 11:38 am EST
  • Posted 8 July 2019, 9:37 am EST - Updated 30 September 2022, 5:41 pm EST
    Could you please recheck after setting “epson tm t20ii printer” as a default printer.
    Please check the paper size in the Printer settings and see if it matched with roll size.
