Report fails with invalid license for Webviewer message
Posted by: charles on 19 March 2023, 11:12 pm EST
    Posted 19 March 2023, 11:12 pm EST
    I support an old application built with ActiveReports 8 which has been running fine for years. Last Thursday an error message began to appear saying " This application will be terminated because it was built with an invalid license for WebViewer. To continue using ActiveReports 8, contact ComponentOne at sales@componentone.com or Order Online. Please send any questions or comments regarding ActiveReports 8, or our other products to http://our.componentone.com." We also have a licence for AR14 but would prefer not to have to upgrade all the AR8 reports to the new platform if possible. Please could you advise if there is a simple solution.
  • Posted 21 March 2023, 7:08 am EST
    Hi Charles,
    Could you please check if your license is showing as ‘Activated’ instead of ‘Invalid’ in your license manager located at ‘C:\Program Files (x86)\Common Files\ComponentOne\Components’?
    If it says ‘Invalid’ please try deactivating and reactivating your ActiveReports 8 with your license key.
    However, if it says ‘Activated’ then in your project within ‘Properties > licenses.licx’ file please make sure you have mentioned the license string reference for your WebViewer:
    GrapeCity.ActiveReports.Web.WebViewer, GrapeCity.ActiveReports.Web.v8, Version=x.x.xxxx.x, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
    You may check more about the available license string references here: License Your ActiveReports: https://help.grapecity.com/activereports/webhelp/Legacy/AR8Help/AR8_HelpOnlineEN/index.html#arHOWLicensingActiveReports.html
    Please Note: The WebViewer is only supported with a Professional ActiveReports 8 License as mentioned in the above-mentioned link.
    Anand
