Report generates "invalid file format (signature)" error message
Posted by: developers on 14 September 2021, 4:42 am EST
    Posted 14 September 2021, 4:42 am EST
    we use Active Reports 14 and have a problem with exporting.
    We get the error message “invalid file format (signature)”. The report contains only the font “Arial”. About the process, we print 20 reports and it is always the same report with different data. Now 10 reports are printed, then one report comes with the error message “invalid file format (signature)” and the remaining 9 reports are printed normally again.
    Is there any way to determine where exactly the problem is?
  • Posted 21 September 2021, 1:33 am EST
    Can you please share the running report with us so that I can replicate the issue at my end. It will be very helpful for us to narrow down the issue.
  • Posted 21 September 2021, 8:11 am EST
    Hello
    How can I send you the report without it being public to everyone?
  • Posted 22 September 2021, 2:10 am EST
    You can open the case using the following link:
    https://www.grapecity.com/my-account/my-support/newcase
    and share the report with us. Also, please make sure that I can report run the report without an issue.
  • Posted 28 September 2021, 2:34 am EST
    I have uploaded the report. As data source we use an XML which is still manipulated by our application.
  • Posted 14 October 2021, 1:04 am EST
    Can you share the ID so that I can look into the case?
  • Posted 14 October 2021, 4:44 am EST
    The case ID: CAS-25552-L0C2V9
  • Posted 18 October 2021, 1:07 am EST
    Case is closed as you shared only the report without the database. Can you please reopen the case and share the required database to run the report.
  • Posted 30 January 2024, 10:39 am EST
  • Posted 2 February 2024, 2:59 am EST
    Hi Ravikanth,
    There can be many reasons behind this issue, like any missing dll or if you are using an unsupported font type. Please note that ActiveReports only supports True Type Fonts (TTF).
    We tried to export a sample report using ActiveReports v17.2.2, and the exported PDF seems to load as expected. We have used Custom Font Resolver. Please see the attached sample. If the issue persists, please try sharing a runnable sample with sample data demonstrating the issue so we can replicate the issue on our end and investigate the issue further.
    You may also refer to the attached documentation link:
    Attachment:CustomFontResolverSample.zip
