Report Viewer with Inserted Pages
Posted by: kim on 11 February 2021, 4:27 pm EST
    Posted 11 February 2021, 4:27 pm EST
    I am creating multiple section reports and combining them into a single report using as follows:
                    for (int y = 0; y < sourceRPT.Document.Pages.Count; y++)
                        hostRPT.Document.Pages.Add(Source.Document.Pages[y]);
    This all works fine when I send to printer and all the pages print, but when I use the Viewer LoadDocument(hostRPT) is rerunning the report and all my added pages are lost.
    How can I get around this or prevent the viewer from running the report?
    TIA
  • Posted 11 February 2021, 11:48 pm EST
    You can use the following code to view the report in the viewer:
    LoadDocument(hostRPT.Document)
  • Posted 12 February 2021, 1:08 am EST
    Thank you!
    Is there any way I can check hostRPT to see if its been run before I call LoadDocument(hostRPT.Document) ?
    If it has not been run then I would need to call LoadDocument(hostRPT)
    TIA
  • Posted 12 February 2021, 6:36 am EST
    You can check the count of the page in hostRPT.Document, if the count is 0 then you need to call the LoadDocument(hostRPT).
  • Posted 21 February 2021, 4:53 pm EST
    Thank you this is what I needed!
