Resource Error in 14.2
Posted by: dnorris on 26 September 2020, 3:11 pm EST
    Posted 26 September 2020, 3:11 pm EST
    I have installed 14,2 using VS 19 version 16.7.3. I move a report from a project using AR 9, I am getting the below error. I think I have tried everything but cannot resolve the issue. Please help.
        Dim resources As System.ComponentModel.ComponentResourceManager = New System.ComponentModel.ComponentResourceManager(GetType(Resources.arEJ150001))
        Return Resources.arEJ150001.ResourceManager
  • Posted 27 September 2020, 12:35 pm EST
    Do you have the image in the report. Could you try to re-add the image and run the application.
    If issue still occurs, could you please share the report with dummy db so that I can run the report at my end.
  • Posted 28 September 2020, 4:22 pm EST
    I can’t re-add the image because I can’t get to the designer.
    Don
  • Posted 28 September 2020, 10:20 pm EST
    Are you facing the error(mentioned in initial post) at design time or runtime?
    Could you please share the screenshot of the SectionReport Designer error.
    If possible, can you share the report with us so that I can look into the report.
  • Posted 29 September 2020, 8:51 am EST - Updated 30 September 2022, 4:56 pm EST
    here is the error I am getting when attempting to design a new form.
  • Posted 1 October 2020, 5:15 am EST
    Please try after manually adding a reference to GrapeCity.ActiveReports.Serializer NuGet package.
    if the problem still occurs:
    Try to reset VS (https://docs.microsoft.com/en-us/visualstudio/ide/reference/resetsettings-devenv-exe?view=vs-2019)
    If the issue is not resolved, please let me know.
