Posted 3 August 2020, 11:54 am EST - Updated 30 September 2022, 4:57 pm EST
The active reports rich text box control does not properly bold text when exported to PDF (or at all apparently). The designer clearly shows that the HTML is bold, but when exported to PDFit shows regular. I tried using RTF and HTML and they both produce the same result. I even modified the HTML to replace tags with tags and that failed as well. I also tried to change the CSS to in-line, that also failed.
How do we get a Rich Text Box to export bolded text to a PDF?
