RichTextBox Error with HTML
Posted by: alexander.kainz on 21 February 2023, 6:06 am EST
    Posted 21 February 2023, 6:06 am EST
    If I fill the RichTextBox with the attached HTML, we got an error.
    I use AR 16.3.2
    I think, the cause of the problem is the image.
    Error:
    System.IO.EndOfStreamException: Unable to read beyond the end of the stream.
    at System.IO.BinaryReader.ReadByte()
    at GrapeCity.ActiveReports.Rendering.Image.ImageHelper.ReadLittleEndianInt32(BinaryReader binaryReader)
    at GrapeCity.ActiveReports.Rendering.Image.ImageHelper.DecodePng(BinaryReader binaryReader)
    at GrapeCity.ActiveReports.Rendering.Image.ImageHelper.GetDimensions(BinaryReader binaryReader)
    at GrapeCity.ActiveReports.Rendering.Image.ImageHelper.GetDimensions(Stream image)
    at GrapeCity.ActiveReports.Core.Rendering.I..(SizeF )
    at GrapeCity.ActiveReports.Core.Rendering.I..( ,  , IEnumerator )
    at GrapeCity.ActiveReports.Core.Rendering.I..LayoutInline( flow)
    at GrapeCity.ActiveReports.Core.Rendering.I..(SizeF )
    at GrapeCity.ActiveReports.Core.Rendering.I..LayoutBlock( flow)
    at GrapeCity.ActiveReports.Core.Rendering.I..Measure(SizeF maxSize)
    at GrapeCity.ActiveReports.SectionReportModel.RichTextBox.GrapeCity.ActiveReports.Controls.IControlInternal.FlexSize(SizeF& size)
    at GrapeCity.ActiveReports.Internal..ProcessFlexSize(Int32 sectionIndex)
    at GrapeCity.ActiveReports.Internal..FormatSection(Section section)
    at GrapeCity.ActiveReports.Internal..PreProcessSectionPhase3(Section section, SectionType sectType)
    at GrapeCity.ActiveReports.Internal..ProcessSectionPhase3(Section section, Boolean& groupFootersDone, Boolean& readyForFinalChecks)
    at GrapeCity.ActiveReports.Internal..ProcessPhase3(Boolean& groupFootersDone, Boolean& readyForFinalChecks)
    at GrapeCity.ActiveReports.Internal..ProcessPageTillFull()
    at GrapeCity.ActiveReports.Internal..GrapeCity.ActiveReports.Layout.IExecReport.RenderPage(Page newPage, Single left, Single top, Single right, Single bottom, ExecMode flags, ExecStatus& status)
    at GrapeCity.ActiveReports.SectionReport.ProcessPage()
    at GrapeCity.ActiveReports.SectionReport.RunImpl(Boolean syncDocument)
    at Liebherr.Cscc.Lios.PdfGenerator.Reports.Services.ReportService.GetTicket(TicketProp ticketProp) in C:\repos\LiOS\LiOS-Report\Liebherr.Cscc.Lios.PdfGenerator\Liebherr.Cscc.Lios.PdfGenerator.Reports\Services\ReportService.cs:line 42
    error.zip
    Best regards,
    Alexander
  • Posted 22 February 2023, 1:58 am EST
    Hi Alexander,
    We could observe you have created a support ticket for the same with ticket ID: CAS-38180-Y7C3L2.
    We have shared our resolution to your support ticket. We’ll request you test our shared sample and reach us on the support ticket if you face any issues regarding the same.
    Anand
