Posted 3 June 2021, 10:28 am EST
I currently have a sub-report which I need rotated 90 degrees when rendered, is that something which can be achieved using Activereports? I am currently working with version 11. Thank you.
Posted by: jamesl on 3 June 2021, 10:28 am EST
Posted 3 June 2021, 1:29 pm EST
Currently, it is not possible to rotate the subreport. Can you please share the use case so that I can help you achieve the same.
Posted 3 June 2021, 2:32 pm EST
My issue is I have an image which I need to rotate 90 degrees based on certain conditions, which can vary page by page in my report. I am placing the image in picture within a sub-report and am unsure if there are any approach’s which I can use with Activereports for this?
Posted 3 June 2021, 10:31 pm EST
Can you please share that which report type(Page/RDL/Section) are using right now? Please share the example in which condition, you want to rotate the image. Also, please share the way that you use to fetch the image in the report.
