rpt.Document.Print takes long to display printer dialog
Posted by: softcomlimited on 12 June 2020, 12:15 am EST
    Posted 12 June 2020, 12:15 am EST
    Mr Mohit,
    When I do
    Dim rpt As GrapeCity.ActiveReports.SectionReport
    rpt.Document.Print(True, True, False)
    the printer dialog takes a long time to display.
    In a previous post you gave me a solution for another problem that might help here. Can you tell me if this is the correct syntax that would do the same as above?
    rpt.Document.Print(GrapeCity.Viewer.Common.PrintingSettings.ShowPrintDialog Or GrapeCity.Viewer.Common.PrintingSettings.UseStandardDialog Or GrapeCity.Viewer.Common.PrintingSettings.ShowPrintProgressDialog)
    I ask because I am not getting the progress dialog.
    Brian
  • Posted 12 June 2020, 12:34 pm EST
    Can you try with the following syntax:
    Document.Print(GrapeCity.Viewer.Common.PrintingSettings.UseStandardDialog);
  • Posted 12 June 2020, 12:41 pm EST
    Mr Mohit,
    Just UseStandardDialog?
    No need for ShowPrintProgressDialog?
    OK, I’ll try it.
    Thanks for the reply.
    Brian
  • Posted 12 June 2020, 1:50 pm EST
    Mr Mohit,
    When I use only UseStandardDialog it prints without giving the user the dialog to choose the printer, I want the dialog to show before printing.
    Brian
  • Posted 15 June 2020, 4:48 am EST
    Sorry for the confusion,
    Have you tried in the simple project with the following syntax:
    rpt.Document.Print(GrapeCity.Viewer.Common.PrintingSettings.ShowPrintDialog Or GrapeCity.Viewer.Common.PrintingSettings.ShowPrintProgressDialog Or GrapeCity.Viewer.Common.PrintingSettings.UseStandardDialog)
    Is it working in a simple project?
  • Posted 15 June 2020, 8:56 am EST
    Mr Mohit,
    As I mentioned originally, it was seeming that I was not getting the progress dialog when I tried
    and I was asking if this was the correct syntax ?
    If it is correct I will go ahead using it since the PrintDialog comes up faster, instead of rpt.Document.Print(True, True, False) but I would like to get the PrintProgress to show.
    Brian
  • Posted 16 June 2020, 2:40 am EST
    Yes, it is the correct syntax. I am able to see the PrintProgess dialog at my end with the same syntax.
    Are you facing this issue only with one application or with all applications?
  • Posted 16 June 2020, 9:37 am EST
    Mr Mohit,
    The problem with the print dialog taking long just started happening in recent days in my dev environment. I am not too sure why so in the meantime I was looking for a workaround and just needed to make sure the syntax is correct for the progress to show. If it is correct then I am guessing the progress not showing might be a symptom of the underlying issue but at least I don’t have to wait 2 minutes for the print dialog to show and I can continue to figure out the main problem.
    Brian
  • Posted 17 June 2020, 3:00 am EST
    I understand the problem. Sorry to mention that I can’t help until I replicate the issue at my end. Please let me know if you have more queries on this.
