Section report with a subreport inheriting a master report problem
Posted by: andrej.jakopic on 12 November 2021, 2:15 am EST
    Posted 12 November 2021, 2:15 am EST
    is it possible to create a section report which includes subreports, that inherits the master report.
    Master report which is inherited works on all section reports, that do not have a subreport.
    The error we get on all the reports with a subreport at runtime is (build or designer view doesn’t have any errors):
    GrapeCity.ActiveReports.ReportException: Report must inherit from GrapeCity.ActiveReports.SectionReport or a inherited SectionReport object with the MasterReport property set to true.
    at GrapeCity.ActiveReports.SectionReport.ValidateInheritance()
    at GrapeCity.ActiveReports.SectionReport.System.ComponentModel.ISupportInitialize.EndInit()
    We are working with Acitve Reports version 15.2.2.
    Best regards,
    Andrej
  • Posted 16 November 2021, 4:33 am EST - Updated 30 September 2022, 4:31 pm EST
    Hi Andrej,
    I couldn’t reproduce the issue at my end and have attached a screenshot of the same. Please make sure you have set the MasterReport property of the master report to true.
    Also, since you already have a ticket open with us (CAS-26702-T5W2M7), please send across your application on that ticket itself, if you’re still facing the issue.
  • Posted 17 November 2021, 3:51 am EST
    Thank you for your answer and support.
    We found the problem with our implementation, while preparing a demo for you. In both cases there was a problem, because instace of a subreport was created before InitializeComponent(). The report itself performed without a problem until a MasterReport was inherited.
    Best regards,
    Andrej
