Section Reports - Hebrew support
Posted by: mlk20 on 11 December 2017, 5:17 am EST
    Posted 11 December 2017, 5:17 am EST
    I would like to evaluate the possibility of using Section Reports to create a report in Hebrew language.
    I need:
    • the ability to use right to left controls layout (designer, viewer, etc…)
    • the ability to create report using Hebrew language (right to left).
    • the ability to merge simple TextBoxes with Hebrew plain text data.
    • the ability to merge complex RichTextBoxes with Hebrew RTF data.
    • the ability to export merged report to PDF format.
    • the ability to export merged report to RTF format.
    Can you please confirm which of the mentioned features are available?
    Can you please provide a simple VS example solution showing how it works in action?
  • Posted 12 December 2017, 7:37 am EST
    Thanks for considering ActiveReports.
    We are glad to tell that all above requirement can be fulfilled by using ActiveReport. Please refer the attached sample to demonstrate the same. You can also refer the documentation links:
    http://help.grapecity.com/activereports/webhelp/AR12/webframe.html#ActiveReports.html
    Also, If you face any issues, we would be happy to assist you.
    rpt_SectionHebrew.zip
  • Posted 3 April 2018, 3:18 am EST
    Another requirement is to use Right to Left feature. Is it supported in AR correctly?
    We tried and there are some issues. See attachments.
  • Posted 3 April 2018, 3:19 am EST - Updated 30 September 2022, 6:24 pm EST
    Hebrew1.zip[img]https://gccontent.blob.core.windows.net/forum-uploads/file-f98cdb1a-8351-4b20-9f10-f216f98080cf.jpg[/img][img]https://gccontent.blob.core.windows.net/forum-uploads/file-bd3e1c04-5d80-4bc3-bb35-4b3b10ac9c2e.jpg[/img][img]https://gccontent.blob.core.windows.net/forum-uploads/file-cb8abf2c-564f-41bf-82c5-277dcdc1d1d9.jpg[/img][img]https://gccontent.blob.core.windows.net/forum-uploads/file-be37217b-f79d-49d8-b706-7d3e50184fcb.jpg[/img]
    See attachments - project and images.
  • Posted 4 April 2018, 8:06 am EST
    AR supports “RightToLeft” feature only in the report. You can change or view the effect the of “RTL” feature in the report through designer, viewer. However, you cannot change the layout of the inbuilt text of designer or viewer control.
    Sorry for the confusion.
