Posted 27 March 2019, 6:10 am EST
Instead of DataDynamics, we now use GrapeCity.ActiveReports.SectionReportModel namespace for sections and controls in SectionReport.
You need to check the type of the required section and when it is found, you can access the controls in that section and do the required operation.
Code snippet for the accessing Page Header section is:
Private Sub Report_ReportStart(sender As Object, e As EventArgs) Handles MyBase.ReportStart
Dim d As GrapeCity.ActiveReports.SectionReportModel.PageHeader
d = Me.PageHeader
Dim type1 As Type = d.GetType
Dim type2 As Type = GetType(GrapeCity.ActiveReports.SectionReportModel.PageHeader)
If (type1.Equals(type2)) Then
For Each ctrl In d.Controls
If (TypeOf ctrl Is GrapeCity.ActiveReports.SectionReportModel.TextBox) Then
CType(ctrl, GrapeCity.ActiveReports.SectionReportModel.TextBox).Text = "This is the PageHeader section of Section Report"
End If
Next
End If
End Sub
A sample report has been attached for your reference.
Best Regards.
AccessSectionInReport.zip
