Posted 10 July 2018, 1:55 am EST - Updated 30 September 2022, 6:04 pm EST
The sample attached.
SectionReportApplication2.zip
Posted by: ilia on 10 July 2018, 1:55 am EST
Posted 10 July 2018, 2:35 am EST
As a workaround, you can set the “WrapMode” property of “Label” to “No Wrap”.
Hope it helps.
Posted 10 July 2018, 3:29 am EST - Updated 30 September 2022, 6:04 pm EST
It helps in this case, but does not in another.
Posted 11 July 2018, 10:51 am EST
This is the design behavior of RTL text. You can see the observe the difference by zooming the viewer. Also, Alignment of RTL text in the exported file is correct.
thanks,
Posted 12 July 2018, 1:01 am EST - Updated 30 September 2022, 6:04 pm EST
First, the text is not RTL-text, but it is aligned to the right.
Secondly, it works fine in AR2 COM.
Thirdly, I do not have the privilege to tell all our customers that this is by design.
I hope this is not so difficult to fix this behavior.
P.S. Distortion only in the first line.
Posted 12 July 2018, 4:52 am EST
I have forwarded the request to our development team(ID 260669) and will inform you once I get any information from them.
Posted 12 July 2018, 7:05 am EST
As per developer comment, the results depend on DPI of system. As WinViewer shows the text via the common System.Drawing API(GDI+), however, AR2 COM uses old GDI. Hence, this is the design behavior of the AR.
Posted 12 July 2018, 12:39 pm EST - Updated 30 September 2022, 6:04 pm EST
GDI+ works fine in the System.Windows.Forms.Form. It is AR12 issue.
Posted 13 July 2018, 5:44 am EST
Hello Ilia,
Yes, this is the issue of AR12. However, this is treated as the limitation of AR.
Posted 13 July 2018, 6:32 am EST
You can fix this limitation.
Posted 16 July 2018, 5:52 am EST
Hello Ilia,
I have forwarded your request to our developers’ team.
Posted 1 August 2018, 7:53 am EST
Hello Ilia,
Could you please try after setting the “CharacterSpacing” to “0.1”
Posted 1 August 2018, 11:43 pm EST
After setting “CharacterSpacing” to “0.0001” of the point, it works perfectly vertically, but the text is cropped horizontally (calculated using “CharacterSpacing” 1).
Posted 2 August 2018, 6:23 am EST
Could you please check it again after deleting the textbox and drag and drop textboxes again?
Posted 2 August 2018, 7:24 am EST
Sample attached.
In my sample the text is not cropped horizontally when “CharacterSpacing” is setting to “0”.
SectionReportApplication2.zip[img]https://gccontent.blob.core.windows.net/forum-uploads/file-49f496d1-e2f1-4709-bc1e-d7a668679e52.png[/img]
Posted 2 August 2018, 7:52 am EST
As a workaround, could you please set “WrapMode” property of “Total 2” label to “No Wrap”
Posted 2 August 2018, 9:17 am EST
Replied 10 July 2018, 2:35 am EST
Hope it helps.
Replied 10 July 2018, 3:29 am EST
Ilia
Posted 3 August 2018, 5:06 am EST
Hello Ilia,
Sorry for the confusion.
Posted 6 August 2018, 7:39 am EST
Hello Ilia,
CharacterSpacing may lead to the wordwrap because word’s width is increased, but it is expected behavior. for the small values like ‘0.001’, the length of whole string may grow to 1px and you need to set the control width with 1mm precision to see the different wordwraps in comparing of ‘0.001’ and ‘0’ values of CharacterSpacing property.
Posted 8 August 2018, 5:40 am EST
Replied 1 August 2018, 7:53 am EST
"Hello Ilia,
Thanks"
Because the CharacterSpacing may lead to the wordwrap because word’s width is increased, your workaround does not help in cases with small text.
To view text in my sample properly i need to increase the width by 0.08 inches (2 mm), which is too much for aligning the text.
Posted 8 August 2018, 6:40 am EST
Hello Ilia,
I have forwarded your issue to our developers’ team.
Posted 9 August 2018, 5:09 am EST
Hello Ilia ,
please check the following code on your machine:
public Form1()
InitializeComponent();
protected override void OnPaint(PaintEventArgs e)
var format = new StringFormat(StringFormat.GenericTypographic);
format.Alignment = StringAlignment.Far;
e.Graphics.DrawString("'WM'", new Font("Arial", 32, FontStyle.Underline), SystemBrushes.ControlText, new RectangleF(0, 0, 180, 90), format);
format.Alignment = StringAlignment.Near;
e.Graphics.DrawString("'WM'", new Font("Arial", 32, FontStyle.Underline), SystemBrushes.ControlText, new RectangleF(182, 0, 180, 90), format);
base.OnPaint(e);
ActiveReports uses the same API in WinViewer control.
Sergey Romanov.
Posted 9 August 2018, 9:11 am EST - Updated 30 September 2022, 6:04 pm EST
How do you do Sergey,
Your code works fine in Form, but WinViewer control looks garbled.
Posted 10 August 2018, 3:23 am EST - Updated 30 September 2022, 6:04 pm EST
Hello Ilia ,
unfortunately, the issue is not reproducible on my machine in both WinForms and ActiveReports projects. here is the original sample of code from developers:
public Form1()
e.Graphics.DrawString("\"WrapMode\" ", new Font("Arial", 10, FontStyle.Underline), SystemBrushes.ControlText, new RectangleF(0, 0, 90, 90), format);
e.Graphics.DrawString("\"WrapMode\" ", new Font("Arial", 10, FontStyle.Underline), SystemBrushes.ControlText, new RectangleF(90, 0, 80, 90), format);
base.OnPaint(e);
Sergey Romanov.
Posted 16 August 2018, 1:37 pm EST
Maybe, MicroSoft will fix this issue within the next six months.
Workaround: Add “\0” in the end of string. (“"WrapMode" \0”)
Posted 27 August 2018, 2:21 am EST
Ilia ,
Thank you for the workaround.
