Posted 11 October 2023, 5:18 am EST
Hi Gregg,
We do not provide support for ActiveReports 7 now as it is a legacy version. We would suggest you to upgrade to the latest version of ActiveReports i.e. ActiveReports 17.
>> I am getting a common error on these Forums, namely: Value cannot be null. Parameter name: instance
Generally, this error is observed when there are incorrect references present in the project. I would suggest you to try the following steps:
- Open the project in Visual Studio.
- Close all designer windows.
- Delete all the ActiveReports 7 references from the solution explorer.
- Re-add the ActiveReports references. You can find the ActiveReports 7 dlls at C:\ProgramFiles\CommonFiles\ComponentOne\ActiveReportsDeveloper7.
- Check the licenses.licx file to see that the version specified matches the ones installed on your machine, or you may remove the version and PublikKeyToken part from the entries.
- Delete the bin and obj folders from your application.
- Clean and Rebuild your solution and try opening the designer again.
Note: ActiveReports 7 is compatible with only Visual Studio 2008, 2010, 2012, and 2013. Also, the Express Editions of Visual Studio do not work with ActiveReports, as they do not support packages.
>> Other topics suggest installing the Serializer from NuGet. When I tried this, it would not allow me to install because my project uses .Net Framework 4. I am running ActiveReports version 7.
This is because ActiveReports 7 does not support adding packages from Nuget Package Manager. Instead, you can find the ActiveReports 7 dlls at C:\ProgramFiles\CommonFiles\ComponentOne\ActiveReportsDeveloper7 location. You can add the GrapeCity.ActiveReport.Serializer dll from the same location.
Click here to find ActiveReports 7 Documentation.
