Set zoom mode in JSViewer initialization
Posted by: hafiz.hassan on 4 August 2022, 4:38 am EST
    Posted 4 August 2022, 4:38 am EST
    Sample here show zoomType can set in JSViewer initialization.
    https://www.grapecity.com/activereportsnet/docs/latest/online/pure-js-integration.html
    <script type="text/javascript">
            GrapeCity.ActiveReports.JSViewer.create({
                element: '#viewer-id',
                reportService: {
                    url: 'api/reporting',
                reportID: 'DemoReport.rdlx',
                settings: {
                    zoomType: 'FitPage'
        </script>
    1. However it is not working and I can’t find any reference to ‘zoomType’ inside jsViewer.min.js
    2. Also no details about ‘settings’ in JSViewer API documentation here:
      https://www.grapecity.com/activereportsnet/docs/latest/online/using-js-viewer.html
  • Posted 5 August 2022, 4:39 am EST
    Please refer to the following points for the resolution of the above query:
    • To set the required zoomMode on initialization, we can use the documentLoaded property to set the required property.
    • To set the zoomMode according to factor, we should set the value of mode as 0, and set the value of factor accordingly (from 0 up to 3 where 0.5 indicate 50% and 3 = 300%)
    • To set the zoomMode as Fit to Width, we should set the value of mode as 1.
    • To set the zoomMode as PageFit, we should set the value of mode as 2.
    Please refer to the following code snippet:
     viewer = GrapeCity.ActiveReports.JSViewer.create({
                  element: '#viewerContainer',
                  documentLoaded: () => {
                      viewer._viewer.zoom = { mode: 1, factor: 0};
    Please let us know if you have any further queries or concerns
    Dushyant Sharma
