Subreport in script for page aspx
Posted by: luca on 18 July 2023, 6:27 am EST
    Posted 18 July 2023, 6:27 am EST - Updated 18 July 2023, 9:51 am EST
    i’m starting to use active Report in page aspx.
    I create in my load the report by :
    Dim rpt As GrapeCity.ActiveReports.SectionReport = New GrapeCity.ActiveReports.SectionReport()
    Dim xtr As System.Xml.XmlTextReader = New System.Xml.XmlTextReader(Server.MapPath(“~\Reports\Example.rpx”))
    rpt.LoadLayout(xtr)
    xtr.Close()
    And now i’d like load also the subreport by script in my report.
    I try something as :
    Dim MySu As GrapeCity.ActiveReports.SectionReportModel.SubReport = me.Mysubreport
    Dim Filename as string = Server.MapPath(“~\Reports\Rpt_subreport.rpx”)
    MySu.LoadLayout(Filename)
    MySu.DataSource = _ds.tables(“table_data”)
    CType(rpt.Sections("PageFooter1").Controls("Sub_report"), SubReport).Report = MySu
    but script don’t accept server.
    After i try to set filename nmanually btt i have proble with command LoadLayout.
    Is correct ‘load’ the subreport in the script in this way ?
    Where can i find some example about this for aspx ?
  • Posted 20 July 2023, 12:01 am EST - Updated 20 July 2023, 12:23 am EST
    Hey,
    To assign a subreport to your parent report you need to assign the ‘SectionReport’ object of the report you want to use as the subreport, please refer to the code snippet below:
            Dim xtr As New System.Xml.XmlTextReader(Server.MapPath("~") + "\RpxReports\Example.rpx")
            _rpt.LoadLayout(xtr)
            xtr.Close()
            Dim xtr1 As New System.Xml.XmlTextReader(Server.MapPath("~") + "\RpxReports\SubReport.rpx")
            _subRpt.LoadLayout(xtr1)
            xtr1.Close()
            CType(_rpt.Sections("Detail").Controls("SubReport1"), SubReport).Report = _subRpt
    Please find attached a sample implementing the same.
    Anand
    WebViewer_ASP.NET_VB.NET.zip
  • Posted 20 July 2023, 4:01 am EST - Updated 20 July 2023, 4:18 am EST
    I have an error on code :
    Dim xtr As New System.Xml.XmlTextReader(Server.MapPath(“~”) + “\RpxReports\Example.rpx”)
    The error is : ‘Server’ not declared. It may be inaccessible due to its protection level.
    I had this code in scripf of report.
    I moved it in load of page and it works.
  • Posted 20 July 2023, 10:23 am EST
    Another question , also connected to this problem.
    I use vb.net , is it possible in the script of a report use function of application ?
    I image to use something like :
    imports Myfunction
    and after use the function in it .
    So it doesnt works :frowning:
  • Posted 21 July 2023, 6:29 am EST
    Hey,
    In order to access a code of your project in the .RPX script you’ll first need to Load your .RPX report into SectionReport class, after which handle the ReportStart event in your project’s code (.cs/.vb) file to add your class using ‘SectionReport.AddNamedItem(“myItem”, new clsMyItem());’ after which you can access your function within .RPX Scripting Section.
    Please find attached a sample implementing the same for your reference.
    P.S.: To learn about loading your .RPX report into Section Report Class please refer to Save and Load RPX Report Files.
    To learn more about giving script access to functions in a class in your project please refer to Add Code to Layouts Using Script.
    Anand
    UseCodeInScript.zip
