Subreport not running
Posted by: nita.kokat on 5 December 2017, 7:28 am EST
    Posted 5 December 2017, 7:28 am EST
    I am using active report version 9.5.6334. I am having main report with 3 subreports. I am running main report but no subreports. StartReport() is not getting fired for subreport. do i need to execute it explicitly or main report take care of it?
  • Posted 5 December 2017, 8:32 am EST
    I tried using subreport1.Run() method but still it is not showing contents on report
  • Posted 6 December 2017, 6:04 am EST
    Did you assign the sub-report instance ‘subreport1’ to the SubReport control’s Report property, as follows:
    controlSubreport.Report = subreport1;
    Doing this would assign your sub-report ‘subreport1’ to the SubReport control ‘controlSubreport’ and then the subreport1’s ReportStart event will automatically fire.
    Also, I suggest you to take a look at product sample SubReport located at …\Documents\GrapeCity Samples\ActiveReports 9\Section Reports\Layout\SubReport\
    If still face any trouble then do let me know.
    Ruchir Agarwal
  • Posted 8 December 2017, 5:54 am EST
    Thanks, working!!
