Timeout on reports that take more than 30seconds to render
Posted by: ricardo.pereira on 22 October 2020, 4:36 am EST
    Posted 22 October 2020, 4:36 am EST
    On our local environment (http://localhost:xx) using the JSViewer to generate a large report that for example takes 60 seconds to finish the [i] http://localhost:5098/api/reporting/reports/test.rdlx/render[/i] request, the report runs perfectly. But once we deployed our solution to a live environment using https , the render requests timeout after 30 seconds.
    This is a bit disappointing because even if it takes a while a user should be able to decide the amount of data he wants to retrieve. Is there any way to override this default timeout?
    This is how we instantiate the JSViewer:
                _scope.viewer = GrapeCity.ActiveReports.JSViewer.create({
                    element: '#viewerContainer',
                    reportService: {
                        url: `${_scope.permissions.reportAPIEndPoint}api/reporting`,
                        securityToken: '42A9CD80A4F3445A9BB60A221D042FCC'
                    availableExports: ['Xml', 'Pdf'],
                    displayMode: 'single',
                    reportLoaded: (reportInfo) => { }, //console.log('The report ' + reportInfo.name + ' was successfully loaded!'),
                    action: (actionType, actionParams) => { }, //console.log('Action type: ' + actionType + '; Action parameters: ' + actionParams),
                    documentLoaded: () => { }, //console.log('The document is loaded entirely on the server'),
                    error: (error) => {
                        if (error.message) {
                            console.log("Internal error! Please ask administrator.");
                            console.log(error.message);
    And we run the reports like this:
                    _scope.viewer.openReport(_config.reportType, reportParameters);
    P.S: We noticed that even after the render request is finished some Progress requests are still made. Shouldn’t the render request be asynchronous and be ultra fast and then the Progress requests should determine if the rendering has been finished?
    Ricardo Pereira
  • Posted 23 October 2020, 10:43 am EST
    I have escalated the issue to the development team(AR-24890) and will inform you once I get any information from them.
  • Posted 25 October 2020, 11:44 pm EST
    Could you please provide the detail steps so that we can replicate at our end.
  • Posted 26 October 2020, 1:32 pm EST
    Hi Mohit,
    First of all thank you for your replies.
    We have found the issue and it was due to our firewall configuration setting a default timeout of 30seconds on http requests.
    Sorry for wasting your time but we appreciate your effort and collaboration.
    Ricardo Pereira
