Trial Version - License Issue with PageReport
Posted by: jeffrey.hughes on 25 June 2020, 8:42 am EST
    Posted 25 June 2020, 8:42 am EST
    We are new to AR and evaluating ActiveReports 14, using the trial version, and receive an error when attempting to run .NET Core unit tests against an assembly using AR14.
    The error is: System.ComponentModel.LicenseException : This application will be terminated because it was built without a license for PageReport.
    I see a .gclicx file generated in the obj\Debug\netcoreapp3.1 folder, but there is no apparent file copied to the bin\debug\netcoreapp3.1 folder. I attempted to copy the gclicx file to bin\debug\netcoreapp3.1 and still received the same error.
    I see messages in the forum regarding a licenses.licx file, but I have no such file in my project. Does this get generated automatically?
    Since we are completely new to AR, if you could elaborate on a solution, we’d appreciate it.
  • Posted 26 June 2020, 9:33 am EST
    Sorry for the inconvenience caused to you.
    I have forwarded your issue to the development team and will inform you once I get any information from them.
  • Posted 26 June 2020, 9:57 am EST
    I have provided the solution in the following case:
    https://supportone.componentone.com/casedetail/443219
    Please use the Forum credential to login to above case.
  • Posted 19 January 2021, 4:24 am EST
    Hello Mohitg,
    We are facing the same issue explained in this topic. We get a “This application will be terminated because it was built without a license for SectionReport.” message when we try to execute the UnitTests. Please, could I access the solution? Thanks,
    Javier.
  • Posted 20 January 2021, 12:02 am EST
    Please refer to the following link:
    https://www.grapecity.com/activereportsnet/docs/v15/online/licensing-compiled-code.html
    If you are using the trial version, then it will not work as trial license popup will fail the unit test.
  • Posted 21 January 2021, 7:07 am EST
    Hello Mohit,
    We already bought a license and the same error still appears. I follow the steps mentioned in the link you posted:
    • Generate .gclicx file
    • Move it to the root of the project with the Unit Tests
    • Change its build action to “Embedded Resource”
    • Rebuild solution
    Could you please send us a solution to the issue?
  • Posted 22 January 2021, 12:21 am EST
    Can you try the following steps:
    Run cmd as administrator
    Switch to C:\ProgramData\GrapeCity\gclm folder
    Enter the following: gclm.exe “de456e2c-d2e3-4246-94e8-9648bbd6fbf0” -lc ./.gclicx [entry assembly name].[calling assembly name].dll"
    Check that .gclicx file is generated in C:\ProgramData\GrapeCity\gclm folder.
    Open the project in which AR assemblies is used
    Add .gclicx file to the above project and make it embedded.
    Fix references, build and run MainExeceutable project
    For example:
    Run the following command:
    gclm.exe “de456e2c-d2e3-4246-94e8-9648bbd6fbf0” -lc “G:\Projects\ActiveReports\QA-Automation\ExportTests\src\netcore.gclicx” “testhost.x86QAExportTests.dll”
    QAExportTests - name of testing dll
    testhost.x86 - nunit host
    Add the “.gclicx” file as Embedded resource to QAExportTests project.
    Hope it helps.
    Use the following ID in case of AR15:
    e88c1aa3-2781-44bb-b639-765c9ef6d15c
  • Posted 22 January 2021, 6:26 am EST
    Hi Mohit,
    Thanks for your answer, but unfortunately we get the same error.
    I will explain the structure of the projects:
    • Our main project is called like → Main.Main.Main
    • The tests project is called like → Test.Test.Test
    So, if I understand correctly, the command should look like this:
    gclm.exe “e88c1aa3-2781-44bb-b639-765c9ef6d15c” -lc ./.gclicx “Main.Main.Main.Test.Test.Test.dll”
    I get the “.gclicx” file and I move to the Test.Test.Test project. I Change it to “Embedded resource” and rebuild the solution.
    Could you please confirm if the steps are correct?
    Kind regards,
    Javier.
  • Posted 25 January 2021, 12:45 am EST
    Pleas use the following command:
    gclm.exe “e88c1aa3-2781-44bb-b639-765c9ef6d15c” -lc ./.gclicx “Test.Test.Test.Main.Main.Main.dll”
    Please move to the “.gclicx” file to “Main.Main.Main” project instead of the “Test.Test.Test”
