Two data source files in one section report
Posted by: joakimsinbox on 30 December 2020, 5:28 pm EST
    Posted 30 December 2020, 5:28 pm EST
    Would it be possible to fetch data from two different data sources in one section report?
    I get data from an external XML-file which I can not edit. I would like to complement my report with additional data. Could this be done by using for example an xls-file as an extra database?
    Could calculated fields somehow be used for this purpose?
    Thanks!
  • Posted 4 January 2021, 12:04 am EST
    You can create the database XML file with additional data. After that, you can bind the newly generated XML file with the Report. There is no way to bind the two datasource with section report directly.
