Unable to Print to Network printer from Web Page
Posted by: tim_artz on 10 October 2019, 11:06 am EST
    Posted 10 October 2019, 11:06 am EST
    I am currently working on a project that will allow reports to be sent to a network printer after they have completed a specific transaction on our web site. We generate the report using Active Reports version 9 and I use the below code on our server side to print the report. I am able to accomplish this when I test from my workstation (using my local IIS) but when I try to do the same action once the site has been updated on our web server the print doesn’t work and I don’t receive any errors. Has anyone had any experience trying to do this?
    Public Sub SendToPrinter(ByVal rpt As SectionReport, ByVal printerName As String, ByVal numberOfCopies As Short)
        Try
            rpt.Document.Printer.PrinterSettings.Copies = numberOfCopies
            rpt.Document.Printer.PrinterName = printerName
            rpt.Document.Print(False, False, False)
        Catch ex As Exception
            Throw
        End Try
    End Sub
  • Posted 11 October 2019, 12:57 am EST
    This occurs when webserver does not have a access to the installed printer. Could you please check in web server printer driver, is print job created on clicking on the print button. If yes, then there must be a problem with the permission issue of the printer. Also, you can also check with the Microsoft PrintDocument. Is issue also reproducible with MS PrintDocument?
  • Posted 11 October 2019, 10:22 am EST
    The printer is not installed locally on the web server. The print works when I run the web site from my computer, when the web site is running from the web server it does not work (NOTE: print driver is not installed on my computer)
  • Posted 14 October 2019, 1:45 am EST
    Could you please check with the following code and see if the print document successfully prints from the WebServer
    Private Sub btn_Print_Click()
            Dim pd As PrintDocument = New PrintDocument()
    	Dim printControl = New Printing.StandardPrintController()
            pd.PrintPage += AddressOf PrintPage
    	pd.PrintController = printControl
            Dim pdi As PrintDialog = New PrintDialog()
            pdi.Document = pd
            If pdi.ShowDialog() = DialogResult.OK Then
                pd.Print()
            End If
        End Sub
        Private Sub PrintPage(ByVal o As Object, ByVal e As PrintPageEventArgs)
            Dim img As System.Drawing.Image = System.Drawing.Image.FromFile("cat.jpeg")
            Dim loc As Point = New Point(100, 100)
            e.Graphics.DrawString("text", New Font("Arial", 10), Brushes.Blue, 100, 100)
        End Sub
  • Posted 16 October 2019, 1:42 pm EST
    I was able to resolve the issue by using memory stream to the network printer (see code below)
    ''' <summary>
    ''' Will send report to network printer using memory stream
    ''' </summary>
    ''' <param name="rpt">Executed Active Report</param>
    ''' <param name="printer">Name of printer and port to send the data.  Printer name and port should be separated by colon</param>
    ''' <param name="numberOfCopies">Number of copies to print</param>
    Public Sub SendToPrinter(ByVal rpt As SectionReport, ByVal printer As String, ByVal numberOfCopies As Short)
        Try
            Using pdf As New PdfExport
                Using memStream As New IO.MemoryStream
                    pdf.Export(rpt.Document, memStream)
                    Using clientSocket As New Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp)
                        Dim printerName = printer.Split(":"c)(0)
                        Dim printerPort = CType(printer.Split(":"c)(1), Integer)
                        Dim hostInfo = Dns.GetHostEntry(printerName)
                        If hostInfo.AddressList.Count = 0 Then
                            Throw New Exception(String.Format("Unable to find printer {0}", printerName))
                        Else
                            Dim ipep = New IPEndPoint(hostInfo.AddressList(0), printerPort)
                            clientSocket.Connect(ipep)
                            For x = 0 To numberOfCopies - 1
                                clientSocket.Send(memStream.ToArray)
                            Next
                        End If
                    End Using
                End Using
            End Using
            Throw
        End Try
    End Sub
