Upgrading from AR13 to AR15
Posted by: peter.herschel on 20 May 2021, 9:29 am EST
  • Posted 20 May 2021, 9:29 am EST
    We use active reports 13 in production. To upgrade to active reports 15, should I uninstall version 13 or can i just install version 15 also. What is the recommended install upgrade path?
    If have both installed can I upgrade projects when it’s time to create new reports?
    -Pete
  • Posted 20 May 2021, 1:55 pm EST
    AR13 and AR15 cannot install side by side. I suggest you to create a test machine to upgrade all your project to AR15. Then, you can uninstall the AR13 on the main machine and install the AR15.
