Use NewFontType in PDF Export
Posted by: siva.sradhananda on 19 February 2019, 2:41 pm EST
    Posted 19 February 2019, 2:41 pm EST
    We are generating PDF’s from a server and we are using a special font in PDF. When we run the web application from our local machine, fonts are working fine. But when we run the application from the web server fonts are not rendered. We are using the Active Reports 9 version.
    Note: We already installed the new fonts in the web server
  • Posted 20 February 2019, 5:20 am EST
    You can use the Custom font Factory to achieve the desired result. You can refer to the following documentation link and attached sample for complete implementation.
    https://help.grapecity.com/activereports/webhelp/AR12/webframe.html#PDFCustomFontFactory.html
    You can download the sample from the following link:
    https://www.dropbox.com/s/li2rw0oat20fpzr/CustomFontFactory.zip?dl=0
