Using Script References and Preview
Posted by: bplante on 17 June 2019, 1:14 pm EST
    Posted 17 June 2019, 1:14 pm EST
    I’m wondering if it’s possible to use the ```
    AddScriptReference
    Ben
  • Posted 18 June 2019, 5:11 am EST
    You can do the following steps;
    1: Create the custom assembly with strong name and register it to GAC
    2: Create a new sample with section report(XML based)
    3: Add report designer to form
    4:Add your code in Script section of the report like as follow:
    public void detail_Format()
    ClassLibrary1.Class1 test = new ClassLibrary1.Class1();
    this.textBox1.Text = test.s;
    5:Add the following code in “Form_Load” event
    SectionReport rpt = new SectionReport();
    System.Xml.XmlTextReader xtr = new System.Xml.XmlTextReader(@“…..\SectionReport2.rpx”);
    rpt.LoadLayout(xtr);
    xtr.Close();
    rpt.AddScriptReference(@“C:\Users\mohitg\Documents\Visual Studio 2017\Projects\ClassLibrary1\ClassLibrary1\bin\Debug\ClassLibrary1.dll”);
    designer1.Report = rpt;
    6: Run the sample
    Hope it helps.
