Vb.net + AR 10 100 Percent Stacked Area Chart
Posted by: douglass on 18 September 2018, 9:15 am EST
    Posted 18 September 2018, 9:15 am EST
    Hi
    Please send me code for Vb.net + AR 10 100 Percent Stacked Area Chart. I also want to change the colors of the different series.
  • Posted 19 September 2018, 5:39 am EST
    Please refer to the “Charting” sample product sample. You can find the same at the following location:
    C:\Users\mohitg\Documents\GrapeCity Samples\ActiveReports 10\Section Reports\Layout\Charting\VB.NET
    Also, you can refer to the following documentation links:
    http://help.grapecity.com/activereports/webhelp/AR10/webframe.html#arWLKChartWalkthroughs.html
    If you are using Page/RDL report, Please let me know.
    Hope it helps.
  • Posted 25 September 2018, 7:05 am EST
    Hi
    Thank you, but this does not help me. I have a stack area percentage report. I have figured it out how to change the colors, but my chart goes to 200% and not 100%. I sort of got this right. I use vb.Net code in a section report. I also see that my first year duplicates and it omit my last year on the X- axis.
  • Posted 25 September 2018, 7:09 am EST
    Here is the graph
  • Posted 25 September 2018, 7:12 am EST
    Could you please attached the file in “Zip” format. Because only “Zip” and “png” format is supported.
  • Posted 25 September 2018, 9:53 am EST - Updated 30 September 2022, 6:00 pm EST
  • Posted 26 September 2018, 5:33 am EST - Updated 30 September 2022, 6:00 pm EST
    I have created the application for you show how to implement the “Stacked100Percent” chart. Please refer to the attachment.
    Hope it helps.
    if the issue still is not resolved, please let me know.
    Stacked_Bar_VB.NET.zip
  • Posted 26 September 2018, 5:55 am EST
  • Posted 26 September 2018, 7:11 am EST
    Hi
    My code and your code is the same, but I still get the duplicate year thing on the x-axis.
  • Posted 26 September 2018, 7:23 am EST
    Have you grouped the data by “Year” in the SQL query?
  • Posted 26 September 2018, 8:08 am EST
    No, I have just Order by year. There is no aggregated functions and it is daily data.
  • Posted 26 September 2018, 8:15 am EST
    In my understanding, you need to group the data by “Year” to show the distinct value of “Year” in the chart. Also, If you grouped the data you need to aggregate the data by some function to show value in the chart as per year.
    Am I missing anything?
  • Posted 26 September 2018, 8:15 am EST - Updated 30 September 2022, 6:00 pm EST
    Seems it has something to do with the spacing of the labels.
  • Posted 26 September 2018, 8:21 am EST
    Yes, If you can’t group them then it shows the all the year value. If you extend the chart, you will see the more year label. So, I would suggest you to group them by year.
  • Posted 26 September 2018, 8:35 am EST
    Ok, maybe I miss something .
    I need the daily Values to display. I build in the sum now and group by the Date
    SELECT MyDescription = (Select Year(ValuationDate)),
    		sum(F.PortfolioValue) as MyValue, sum(F.CashValue) as MyValue2
    From PortfolioAssetAllocationFinal F
    Where F.ReportingPortfolioID = @ReportingPortfolioId
    And F.ValuationDate <= @ValuationDate
    Group By  ValuationDate
    Order By MyDescription
    The data looks then like this (2761 rows), which is exactly the same as without the sums and group by., but the graph still looks the same. Is there no way to switch off duplicate labels?
    2008 100 0
    2008 100 0
    2008 100 0
    2008 100 0
    2008 100 0
    2008 60 40
    2008 60 40
    2008 60 40
    2008 60 40
    2008 60 40
    2008 20 80
    2008 20 80
    2008 20 80
    2008 20 80
    2008 20 80
    2008 10 90
    2008 10 90
    2008 10 90
    2008 10 90
    2008 10 90
    2008 10 90
    2008 10 90
    2008 10 90
    2008 10 90
  • Posted 26 September 2018, 8:59 am EST
    Please try the following SQL query
    SELECT
    From
    Where
    Group By
      Year(ValuationDate)
    Order By
      MyDescription
    Hope it helps.
  • Posted 26 September 2018, 9:07 am EST
    Try that, but then you do not get they daily or even monthly values.
    It return, which is totally wrong.
    2008 10490 15710
    2009 11850 14250
    2010 14590 11510
    2011 19650 6350
    2012 22920 3180
    2013 25000 1100
    2014 24250 1850
    2015 23900 2200
    2016 17630 8470
    2017 22180 3820
    2018 6030 9170
    2008 10490 15710
    2009 11850 14250
    2010 14590 11510
    2011 19650 6350
    2012 22920 3180
    2013 25000 1100
    2014 24250 1850
    2015 23900 2200
    2016 17630 8470
    2017 22180 3820
    2018 6030 9170
    2008 10490 15710
    2009 11850 14250
    2010 14590 11510
    2011 19650 6350
    2012 22920 3180
    2013 25000 1100
    2014 24250 1850
    2015 23900 2200
    2016 17630 8470
    2017 22180 3820
    2018 6030 9170
  • Posted 26 September 2018, 9:11 am EST
    Could you please explain the data you want to show in the chart. How the chart should appear? Which data do you want to show on X axis? Which data do you want to show on Y axis?
  • Posted 26 September 2018, 9:21 am EST
    the chart as it is, is correct now, except for the x Axis repeating labels. the year show more than once and the last year is omitted.
    thus
    X- axis → the year
    Y -axis → the percentage value
    graph series 0 and 1 → the daily values as captured in the database.
    series(0)
    ValueMembersY -->PortfolioValue (MyValue1)
    ValuemembersX–> Year (MyDescription)
    Series(1)
    ValueMembersY -->CashValue (Myvalue2)
  • Posted 26 September 2018, 10:23 am EST
    As a workaround I suggest you to loop through the points collection.
    By looping through the points collection, you’d be able to set some sort of boolean for each month. If it’s the first time the year has been displayed(the xvalue of the points), add “2008” or “2009” etc to the axis x labels collection. Otherwise, add an empty string. Like below
     Dim CurrentYear = 0
            For i As Integer = 0 To chartControl1.Series(0).Points.Count - 1
                If chartControl1.Series(0).Points(i).XValue <> CurrentYear Then
                    chartControl1.Series(0).AxisX.Labels.Add(chartControl1.Series(0).Points(i).XValue)
                    CurrentYear = chartControl1.Series(0).Points(i).XValue.ToString
                Else
                    chartControl1.Series(0).AxisX.Labels.Add(" ")
                End If
            Next
    Also, Please adjust the “LabelsGap” property to adjust the “Labels” on X Axis.
    Hope it solves your problems.
  • Posted 27 September 2018, 4:20 am EST
    As per your requirement, you need to show data according to daily/monthly basis on the chart. If you bind the X-axis with year column(extracting from the date column) then, its by-design behavior to show the duplicate value of “Year” on X-axis. Because the “Year” column contains the duplicates value. Hence, this is the design and correct behavior of the control.
    Also, you do not want to group them as per year because you need to show the data as per daily/monthly basis. So, the only way to achieve this to follow the suggestion given in my previous reply.
    If there is anything else that you want to confirm, please let me know.
  • Posted 27 September 2018, 6:18 am EST
    Hi Mohitg
    Thank you. I have tried your suggestion, but it have no effect. Where must I place the code? I have placed it on different places, but no effect. I place it just after binding the series(0).ValueMemberX and y. Then just after adding the series and then then I also tried to put it in the Detail_BeforePrint sub. still no effect. I then did it in SQL, but then I get weird numbers on the graph.
  • Posted 27 September 2018, 6:49 am EST
    You can add the code in “DetailFormat” event after assigning the value to series. Please refer to the attached sample.
    Stacked_Bar_VB.NET_modfied.zip
  • Posted 27 September 2018, 7:55 am EST - Updated 30 September 2022, 6:00 pm EST
    Hi
    Tried that, not working. Then I removed your code and just set the label gap to 60. I then get the following graph. Now only the first year is duplicated. Tried to remove the first axis label, but this is also not working.
  • Posted 28 September 2018, 3:56 am EST
    Could you please share the application of your chart along with DB so that I can find the workaround if exits.
  • Posted 28 September 2018, 4:33 am EST
    Graph Data.zip
    Good Morning
    I have put my code and data in text files for you in the zip folder. Thank you for your help.
  • Posted 28 September 2018, 5:06 am EST - Updated 30 September 2022, 6:00 pm EST
    Please adjust the “LabelGap” property until the desired result achieved. I have adjusted the “LabelGap” (290) at my end and achieved the desired result.
