Web Designer 2 Bugs
Posted by: kevin.gunn on 8 October 2019, 9:00 am EST
    Posted 8 October 2019, 9:00 am EST
    After successfully integrating the Web Designer into our application, and extensive use, we have come across 2 bugs that I wish to bring to your attention.
    1. If you click on TextBox in the toolbox, this places it at the position Left: 0, Top 0, or just place a TextBox in this location, you are unable to double click on it to enter the value.
    2. Just adding an empty table to a page, makes the pages duplicate 6 times when previewing.
    Kev
  • Posted 9 October 2019, 3:01 am EST
    Hello Kevin,
    I have checked this at my end with Webdesigner sample or when we use WebDesigner in IFrame, However, I am not able to replicate the issue at my end. I think this is issue is related to your sample or occur in a very specific scenario. Could you please explain more so that I can able to reproduce the issue at my end.
    When you add the empty table, It binds with the dataset by default. Table renders on the report as per data in the dataset. You can try the same after removing the dataset from the report. Also, you can’t use the table without the dataset in the report. For every data region control(Table, Tablix, List etc), you must have a dataset in the report.
    Hope it clarifies.
  • Posted 9 October 2019, 3:25 am EST
    Hi Mohit,
    I can also reproduce the unable to double click on it to enter the value. in the MVC Example supplied with AR13, sorry I forgot to say that you set the margin on the report to None
    For the Table, I am only providing one set of data for preview.
  • Posted 9 October 2019, 6:10 am EST
    Thanks for additional information, I am able to replicate the issue at my end and have escalated the same(ARD-768) to our development team.
    Could you please check after binding any field of the dataset with Table. Is it still rendering in 6 pages with data? Table always render according to record in the dataset. Could you please mentioed how many records present in the dataset. Also, it not recommended to use Table without dataset. You can use the TextBox instead of Table if you do not want to bind with the dataset.
  • Posted 11 October 2019, 7:21 am EST
    I am glad to tell you that this issue is fixed in the latest hotfix of AR13 SP2. You can download the same from the following link:
    http://cdn.grapecity.com/ActiveReports/AR13/hotfixes/ActiveReports-v13.2.18593.0.msi
  • Posted 15 October 2019, 2:43 am EST
    Great Thanks Mohit,
    I will apply the hot fix and will feedback.
    Kev
