WebViewer PDF OnlyForPrint
Posted by: stacey.manske on 16 July 2020, 10:35 am EST
    Posted 16 July 2020, 10:35 am EST
    I’m upgrading ActiveReports from version 12 to 14 and was using the WebViewer flash startprint option to automatically bring up the print dialog.
    Updating the viewer and switching to the PDF OnlyForPrint works but when you print and then click a link to go to another page and then use the back button, the print dialog with the report pops up again. Is there any way to prevent that?
  • Posted 17 July 2020, 7:38 am EST
    You can use the following line of code to prevent that:
    public string test
                get
                    return (string)Session["test"] ?? "hi";
                set
                    Session["test"] = value;
            protected void Page_Load(object sender, EventArgs e)
                if(test=="test")
                this.WebViewer1.PdfExportOptions.OnlyForPrint = (bool)Session["print"];
            protected void Button1_Click(object sender, EventArgs e)
                Session["test"]= "test";
                Session["print"] = false;
                Response.Redirect("WebForm2.aspx");
    MOhit
