Win.Viewer LoadComplete event not firing
Posted by: rachel.gray on 26 October 2017, 9:54 am EST
    Posted 26 October 2017, 9:54 am EST
    I’m wanting to exporta page report to pdf, and have put the code to do so in the Loadomplete event of the Win.Viewer I am loading the report into. This works fine if the LoadComplete event fires, but it doesn’t always do this!
    How can I find out why the load has failed? Is there a property of the viewer or document I can look at? Or an event I can handle?
    At the moment my code is
    	PageReport = new PageReport();
                PageReport.Load(new System.IO.FileInfo(rdlxFileLocation));
                PageDocument = new PageDocument(PageReport);
    //parameters and datasources set dynamically
       AdvancedViewer = new GrapeCity.ActiveReports.Viewer.Win.Viewer();
            AdvancedViewer.LoadCompleted += AdvancedViewer_LoadCompleted;
            AdvancedViewer.LoadDocument(PageDocument);
    Rachel
  • Posted 27 October 2017, 8:46 am EST
    Hi Rachel,
    I created a sample application to test the behavior described by you and found it to be working correctly. Please refer to the attachment.
    I would request you to please modify the sample application and send it back to me, in case the issue still persists.
    Deepak Sharma
    ARPage_ViewerLoad.zip
