XLSX Cannot Download From OWA
Posted by: afrancisco on 10 October 2018, 12:28 pm EST
    Posted 10 October 2018, 12:28 pm EST
    We have an odd case where when we email XLSX generated reports, we cannot download the XLSX file through OWA. It works OK on other email clients.
    We tried with other XLSX reports (not generated by AR) and they all seem to work through OWA.
    Easy way to reproduce is to attach the included attachments in an email. Open the email through OWA and try to download the attachments. The AR generated XLSX becomes corrupted, while the other works just fine. Open the email in Outlook, and both can be downloaded successfully.
    My initial investigation led me to an OWA feature called SafeHTML. Attempting to disable this feature still didn’t resolve the issue. There appears to be something in the AR generated XLSX that OWA doesn’t like.
    AR v10
    Exchange-OWA 2010
    Adrian
  • Posted 10 October 2018, 12:31 pm EST
  • Posted 11 October 2018, 2:33 am EST
    I am unable to reproduce the issue at my end with the attached excel. We also use the "Office 365’ for the mailing purpose. I mailed the attached file to one of my colleagues and excel file opened successfully at his end. There may be a security setting in your OWA. Please contact with your administration department to know the detail. Also, please share the detail with us so that, we can try to replicate the issue at our end.
  • Posted 11 October 2018, 9:57 am EST
    Ya, it’s not the easiest of environments to setup to reproduce this issue, considering it’s pretty old. I am running a local instance of Exchange 2010 in a virtual machine, so it’s all in a testing environment, no admins. Office 365 works fine, it’s just OWA in Exchange 2010.
    Anyways, it’s OK, this is a pretty minor issue so I’m not all too concerned about it. I just thought maybe you were aware and had a quick fix.
    Thank you for your time.
  • Posted 16 October 2018, 6:32 am EST
    Thanks for the information. However, I have escalated the issue to our development team(265802) and will inform you once I get any information from them.
  • Posted 16 October 2018, 7:02 am EST
    Could you please try after changing the different values of “OpenXmlStandard” property.
  • Posted 22 October 2018, 11:43 am EST
    I tried changing OpenXmlStandard from Transitional to Strict and it does seem to work in OWA. However, I’m not sure if I’ll be able to switch to using Strict as the documentation states that this standard is not supported for Office 2007 and lower. I’ve attached the output files to possibly check for differences.
  • Posted 22 October 2018, 11:44 am EST
  • Posted 23 October 2018, 6:15 am EST
    I have forwarded the detail to our development team and will inform you once I get any information from them.
  • Posted 29 October 2018, 1:42 pm EST
    Hello, just wondering if there’s any update on this?
  • Posted 30 October 2018, 7:58 am EST
    Our development team does not have the same environment to replicate the issue at their end. It will take some time to create the environment and investigating the root cause of the issue. However, as you said earlier this is the minor issue for you. so we consider this issue as the low priority.
