Posted 28 September 2017, 4:39 pm EST
[activereports_archive]Hello, I am using ActiveReports 2.0 with .NET 1.1.
Duing batch processing of active reports where the batch size is > 1000 reports I get the following error:
ErrText
System.Exception: IN gaEpr.gaEprRun AT STAGE: Execute method invoked
—> System.Exception: IN oaBtc.oaBtcPrc AT STAGE: Mapping parameter out: pvntTemplateParms
—> System.ComponentModel.Win32Exception: Error creating window handle.
at System.Windows.Forms.NativeWindow.CreateHandle(CreateParams cp)
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.TextBoxBase.CreateHandle()
at System.Windows.Forms.Control.get_Handle()
at System.Windows.Forms.RichTextBox.ForceHandleCreate()
at System.Windows.Forms.RichTextBox.set_SelectedText(String value)
at System.Windows.Forms.TextBoxBase.AppendText(String text)
at Fast.ogTmp.ogTmpObj.SetLetterData(ggFdaCls pfdaLetterData, ggFdaCls pfdaTableData)
at Fast.ogTmp.ogTmpObj.GenerateLetter(ggFdaCls pfdaPrintGroup, ggFdaCls pfdaMailItem, ggFdaCls pfdaLetterData, ggFdaCls pfdaTableData, ggFdaCls pfdaPreviousMailItem, Int32& plngEnvelopePageCount, Int32& plngLetterPageCount, Int32& plngLettersInBatch, Boolean& pblnSuspendPrintForLetter, Boolean& pblnNewEnvelope, String pstrPrintControlObject)
at Fast.oaBtc.oaBtcPrc.Execute(Int32& plngMailBatchKey, String& pstrFileOutputName, Int32& plngVerLastCurrent)
— End of inner exception stack trace —
at Fast.ggBom.ggBomBas.ExecuteMessage(ggMsgObj& pMsg)
at Fast.gaEpr.gaEprRun.Execute(Object pvntMsgArcData, Int32 plngQueueKey, Int32 plngVer, Int32 plngVerLast, String pstrKey, String pstrEvent, String pstrSource, String pstrDestination, DateTime pdtmQueued, Int32 plngDeleted, DateTime pdtmIntervention, DateTime pdtmHoldTill, Int16 pintAttempts, Int32 plngCustomerKey, Int32 plngAccountKey, String pstrSourceQ, String pstrSuccessCriteria, String pstrData)
at Fast.ggBom.ggBomBas.RootExecute(Int32 plngRootKey, ggMsgObj& pMsg, ggLbiMsx& pMsx)
My batch processing class creates a new empty ‘batch’ report and loops running reports that are destined for the batch. report pages are appended to the batch report until the batch report is >=200 whereupon the ‘batch report’ is exported to a temporary pdf and .dispose( ) is called on it. At the end of the loop the temporary pdfs are merged into the final batch pdf. I have pasted the dispose methods called on the batch report below.
I figure that all the controls on the reports are exceeding the 10k limit of window handles Windows allows to a .NET process, but I was hoping that exporting every 200 pages to a temp pdf and disposing of the batch report would free up the handles allowing me to run large batch sizes. Any ideas?
Private Sub DisposeActiveReport(ByRef pReport As DataDynamics.ActiveReports.ActiveReport)
pReport.Cancel()
For i As Integer = 0 To pReport.Sections.Count - 1
pReport.Sections(i).Controls.Clear()
pReport.Sections(i).Controls.Dispose()
Next
pReport.Sections().Clear()
pReport.Sections.Dispose()
pReport.Document.Pages.Clear()
pReport.Document.Dispose()
pReport.Dispose()
pReport = Nothing
End Sub[/activereports_archive]
