Error when using Script in Report
Posted by: sourcelink on 28 September 2017, 6:42 pm EST
    Posted 28 September 2017, 6:42 pm EST
    [activereports_archive]I created a report that pulls data from a SQL database and it works fine until I add script code on the report.
    In my development machine it shows an error for a missing dll related to a camera control, which we use.
    On a testing machine the error mentions another dll related to quickbooks which we also use, but it is present and installed.
    Please advice.
    [/activereports_archive]
  • Posted 28 September 2017, 6:42 pm EST
    [activereports_archive]No answer to my post?[/activereports_archive]
    [activereports_archive]Could you please provide me the RPX file of your report which throws this exception? Are you using some code in the script referring to the camera control dll or dll related to quickbooks?
    Ankit Nigam
    [activereports_archive]I am not using a RPX file. I am using a form in VB.NET 2008.
    Do you want the form files?
    I am not using any code for cameras or quickbooks. This is the script I am using on the report.
    Function ActiveReport_FetchData(ByVal EOF As Boolean) As Boolean
    If me.rpt.fields(“unittype1”).value=2 Then
    me.rpt.sections(“Detail1”).controls(“Weight1”).visible=false
    End If
    If me.rpt.fields(“unittype1”).value=1 Then
    me.rpt.sections(“Detail1”).controls(“Quantity1”).visible=false
    End If
    If me.rpt.fields(“unittype2”).value=2 Then
    me.rpt.sections(“Detail1”).controls(“Weight2”).visible=false
    End If
    If me.rpt.fields(“unittype2”).value=1 Then
    me.rpt.sections(“Detail1”).controls(“Quantity2”).visible=false
    End If
    If me.rpt.fields(“unittype3”).value=2 Then
    me.rpt.sections(“Detail1”).controls(“Weight3”).visible=false
    End If
    If me.rpt.fields(“unittype3”).value=1 Then
    me.rpt.sections(“Detail1”).controls(“Quantity3”).visible=false
    End If
    If me.rpt.fields(“unittype4”).value=2 Then
    me.rpt.sections(“Detail1”).controls(“Weight4”).visible=false
    End If
    If me.rpt.fields(“unittype4”).value=1 Then
    me.rpt.sections(“Detail1”).controls(“Quantity4”).visible=false
    End If
    ActiveReport_FetchData = EOF
    End Function[/activereports_archive]
    [activereports_archive]Hello,
    Have you used the AddScriptReference method to make reference to the Assemblies you are using in your script?
    Prantik[/activereports_archive]
    [activereports_archive]The error I get is on the report editor during the preview.
    I am not using any assemblies on my script. Or the code I added is considered an assembly?[/activereports_archive]
    [activereports_archive]If I add the reference for addscriptreference I get an error when I run the code on my development machine.
    This is the message I am getting.
    Please fix the error in teh code and rebuild the project.
    Error message: could not load file or assembly ‘ActiveReporst6, Version-6.0.1797.0, Culture=neutral, PublicKeyToken=cc4967777 c49a3ff’ or one of its depedendencies. The system cannot find the file specified.
    I really need a response to this issue please.[/activereports_archive]
    Can you send the report files? If you are creating the report through code, can you send us the form file where you have created the same? Besides, is it a windows application or an web project?
    [activereports_archive]Hi,
    it is a windows application.
    I sent the files in a zipped file. I added an extra x to the extension to fool my email, please edit the files to be vendorform.vb and vendorform.resx[/activereports_archive]
    [activereports_archive]You can send the files on support@grapecity.us.com and also mention the forum link in the mail.
    Ankit Nigam
