How to dynamically make a image object visible
Posted by: robertvmp25 on 12 June 2019, 1:33 am EST
    Posted 12 June 2019, 1:33 am EST - Updated 30 September 2022, 1:00 pm EST
    I’m a beginner on ActiveReport. I wonder how to dynamically make a image object visible depending on specified rules.
    Here is my conditions:
    Back end: Java Servlet + Java-script
    ( to call a ActivReport Object RunViewer to run with 123.rpx
    by assigning
    Server=http://xxx.xxx.xxx.xxx/ReportExpress/
    ReportLayout = 123.rpx )
    Front end: IE explorer to call active report viewer with 123.rpx
    (with a image object named “image1” , its property:visible= true )
    Here is my problem
    How can I dynamically make the image1 invisible depending on my rules
    it means how to set the visible = false
    Please refer to my attached file for further information.
    I would appreciate your help. Thanks in advance.
  • Posted 13 June 2019, 5:34 am EST
    I am assuming you are using AR3 version of the AR. Sorry to mention that AR3 is a legacy product a long time ago. It is out of maintenance mode now. Hence, we don’t provide support for the same. I would recommend you to upgrade to AR13 for the latest feature.
    You can refer to the following link to more information on our latest version.
    https://www.grapecity.com/activereports
    However, you can use the “Format” event of the “Detail” section to set the visibility of the Image on the particular value. Please refer to the following links:
    https://help.grapecity.com/activereports/webhelp/Legacy/ARNET3/ar3conSectionEvents.html
    https://help.grapecity.com/activereports/webhelp/Legacy/ARNET3/ar3conScripting.html
