Need to have localized resource dll signed
Posted by: novajiang1 on 6 August 2019, 4:39 am EST
    Posted 6 August 2019, 4:39 am EST
    We are using Active Report 6 professional.
    zh-CN Designer for end-user is required.
    When I send resources.dll to powersupport@gcGrapeCity.com
    for J"Need to have localized resource dll signed"
    got an error:
    Host unknown (Name server: gcgrapecity.com.: host not found)
    Did I sent to wrong mail address?
    The Dlls are attatched .
  • Posted 6 August 2019, 4:41 am EST
    Please help us.
    AR6.zipl
  • Posted 6 August 2019, 6:30 am EST
    Thank you for sharing the files. I am getting them signed for you (Internal Tracking ID: 274835).
    Will get back to you once it is done.
  • Posted 6 August 2019, 6:44 am EST
    Here are the signed dlls.
    SignedDLLs.zip
  • Posted 15 August 2019, 10:39 pm EST
    How to add SignedDlls and deploy by Click-Once exe ?
  • Posted 19 August 2019, 4:53 am EST
    Sorry to mention that I could not understand your actual requirement. Could you please explain in detail.
    Also, you can refer to the following documentation link of MSDN:
    https://docs.microsoft.com/en-us/visualstudio/deployment/how-to-publish-a-clickonce-application-using-the-publish-wizard?view=vs-2019
  • Posted 20 August 2019, 2:59 am EST
    Scenario 01: in pure EXE, got zh-CN form.
    Step1. Copy ActiveReports.Design6.resources.dll to bin\Debug\zh-CN
    Step2. Execute bin\Debug\ActiveReportDesignerTest02-vs2010.exe(SC10_Execute01.png)
    Step3. Choose zh-CN,Get zh-CN form(SC11_Choose-zh_CN.png, SC12_DesignerWithZH-CN.png)
    Scenario 02:
    Package Click-Once
    Step1. Package Click-Once (SC20_ClickOnce-Package.png)
    Can’t found zh-CN\ActiveReports.Design6.resources.dll
    Step2. Deploy Click-Once to IIS Server
    Step3. Execute Click-Once
    http://Server/VS2010-ActiveReport/ActiveReportDesignerTest02-vs2010.application
    (SC30_LinkToClickOnceStartPage.png~SC34_ClickOnceAP_NoZH-CN.png)
    Step4. Choose zh-CN,No zh-CN
  • Posted 20 August 2019, 3:00 am EST
    Photos.
    Photos.zip
  • Posted 20 August 2019, 3:08 am EST - Updated 30 September 2022, 1:00 pm EST
    I can’t send zipped Source Code .
  • Posted 20 August 2019, 6:43 am EST
    Please try the following steps:
    1: Add the “zh-CN” folder which contains the resource dll in your project.
    2: Set the “CopyToOutputDirectory” to Copy Always or Copy if newer.
    3: Deploy Click-Once to IIS Server
    4: Execute Click-Once.
    Please share the result with us. Also, you can share the sample at the following link:
    https://www.dropbox.com/request/pprgRUGcO6evALDBlZUj
  • Posted 20 August 2019, 7:01 am EST
    It is OK.
    The files were sent to dropbox.
  • Posted 20 August 2019, 7:15 am EST
    Have you tried the step mentioned in my previous reply?
    Is issue still replicate after trying the above steps?
  • Posted 21 August 2019, 3:23 am EST
    Our Architecture decided , change LangCultureNames to zh-CHT, zh-CHS
    Please sign the DLLs for us.
    Dll
    zh-CHS/ActiveReports.Design6.resources.dll
    zh-CHS/ActiveReports.Document.resources.dll
    zh-CHS/ActiveReports.Viewer6.resources.dll
    zh-CHT/ActiveReports.Design6.resources.dll
    zh-CHT/ActiveReports.Document.resources.dll
    zh-CHT/ActiveReports.Viewer6.resources.dll
    NotSigned-DigihuaZHLang-GrapCity.zip
  • Posted 21 August 2019, 8:40 pm EST
    mohitg:
    The steps seems to be workable.
  • Posted 22 August 2019, 3:12 am EST
    I am glad that your issue is resolved now.
  • Posted 22 August 2019, 4:14 am EST
    zh-CHT.zipzh-CHS.zip
  • Posted 22 August 2019, 7:01 am EST - Updated 30 September 2022, 1:00 pm EST
    Mohitg:
    Many thanks for your help.
    I have some not requied lang DLLs( zh-CN, zh-TW)
    How can I removed them?
    I have removed the folders in Project Output path.
    But when I execute Click-Once Deploy.
    the DLLs( zh-CN, zh-TW) will appeare again.(as attatched image)
    How can I undo the Localize.bat operation, remove DLLs from cache?
  • Posted 22 August 2019, 7:31 am EST
    Do you have " zh-CN, zh-TW" folder in your project with CopyToOutputDirectory" to Copy Always or Copy if newer?
    If yes, please delete them from the project folder.
