Posted 28 January 2019, 12:50 pm EST - Updated 30 September 2022, 1:01 pm EST
When I right click on the report designer I do not get a context menu. I cannot add group header/footer.
Forums Home / ActiveReports / ActiveReports v3-6
Posted by: Robert.Sullivan on 28 January 2019, 12:50 pm EST
Posted 29 January 2019, 4:21 am EST
Hello Robert,
Please note that AR 6 is compatible with Visual Studio 2010, at max. The software requirements are stated here:
https://help.grapecity.com/activereports/webhelp/Legacy/ActiveReports6/webframe.html
Kindly share the Visual Studio version you use at your end.
Also, do you observe the same issue with every code-based section report application at your end?
You can also check your projects with the latest AR6 version, available here:
http://cdn.grapecity.com/ActiveReports/legacy/ar6_6.3.4797.zip
