Possible to find ActiveReports3 development package
Posted by: djsisolak on 1 November 2017, 9:39 pm EST
    Posted 1 November 2017, 9:39 pm EST
    Hi! I am working with an application that I have been asked to bring up on Windows 10. The codebase that was given to me appears to have dependencies on ActiveReports3. Is it still possible to acquire the necessary assemblies to rebuild this application? If so, where would i find them?
    thanks,
    DJ
  • Posted 2 November 2017, 7:26 am EST
    Hi DJ,
    Please download AR3 SP3 from the following link - http://cdn.grapecity.com/ActiveReports/legacy/arn3_5314362.zip
  • Posted 2 November 2017, 3:16 pm EST
    Thanks! Ran into a small problem though. The install is telling me that there is no compatible version of Visual Studio.NET installed. i am running VS 2015. Is that not compatible with AR3?
    thanks again!
  • Posted 3 November 2017, 7:38 am EST
    Unfortunately not. AR3 was released much earlier than VS2015 and requires Microsoft .NET Framework Version 1.1 SP1 or 2.0 as stated in the documentation.
  • Posted 5 November 2017, 6:12 pm EST
    I did install MS .NET SDK 2.0 and I can see it in my control panel list of installed applications. I also enabled .NET 3.5 in the control panel which is supposed to contain 2.0. What else am I missing?
    Thanks again!
  • Posted 6 November 2017, 2:23 am EST
    Do you still get the same error? If you do, then you would also need Visual Studio 2005 to be able to install AR3.
  • Posted 7 November 2017, 10:35 am EST
    Ok, that is what I suspected. In that case, what would be the current version of AR that would be most compatible with the AR3 apis? I need to be able to get this to run on Windows 10.
    Thanks again!
  • Posted 14 November 2017, 5:20 am EST
    If you’re looking to upgrade, I would suggest upgrading to the latest version i.e v11. You can look at the new features and enhancements that have been added in v11- http://help.grapecity.com/activereports/webhelp/AR11/index.html#WhatsNew.html
    And to upgrade your AR3 reports to AR11, please see this link - http://help.grapecity.com/activereports/webhelp/AR11/index.html#MigratingVer3.html
    Let me know if you have any other questions
