Posted 22 April 2025, 1:53 am EST
As per my understanding, you want to get the row data whenever the checkbox in checked/unchecked.
By default, there is no event to detect when the checkbox is checked/unchecked. However, you could use the following to get the row index and the row data:
<FlexGrid @ref="grid" ItemsSource="cities" Style="@("max-height:50vh; width: 50%")"
IsVirtualizationEnabled="false">
<FlexGridColumns>
<GridColumn HeaderHorizontalAlignment="C1HorizontalAlignment.Center"
Header="Selected" HorizontalAlignment="C1HorizontalAlignment.Center">
<CellTemplate>
var city = context as City;
<C1CheckBox IsChecked="city.Selected"
IsCheckedChanged="@(v => OnCheckChanged(v.Value, city))">
</C1CheckBox>
</CellTemplate>
</GridColumn>
</FlexGridColumns>
</FlexGrid>
@code {
IEnumerable<City> cities;
FlexGrid? grid;
protected override void OnInitialized()
cities = Customer.GetCities();
private void OnCheckChanged(bool? isChecked, City city)
city.Selected = isChecked == true;
// Get row index using the Id
var rowIndex = city.Id;
// Get the Row Data
City rowData = (City)grid.Rows[rowIndex].DataItem;
Console.WriteLine($"Checkbox changed for city: {rowData.Name}, Checked: {rowData.Selected}, Row Index: {rowIndex}");
You could also refer to the following forum case that discusses the same: https://developer.mescius.com/forums/blazor-edition/flexgrid-checklistbehavior-selection-changed
Further, based on your requirement, you could also create custom column and implement the behaviour that you want. Refer to the following demo on creating custom column: https://developer.mescius.com/componentone/demos/blazor/blazorexplorer/FlexGrid/CustomDropDownColumn
Let us know if you face any issues.
Ankit
FlexGrid_CheckBox.zip
