Posted 15 April 2023, 7:23 am EST
please refer to the example app attached.
- Navigate to “Fetch data” page
- Select cell 0,0 (first column and row)
- Press delete button
If Frozen columns is set to “1” the method PrepareCellStyle is called for column “0” only. If you remove the frozen column, the method is called for all columns. (also check debug log for details.)
I want to format all cells in a row based on validation result.
Because just the frozen column is triggered the other columns are not formatted correctly.
Thank you
Daniel
