FlexGrid AfterSort Event?
Posted by: jared.fritsch on 9 November 2017, 11:00 am EST
    Posted 9 November 2017, 11:00 am EST
    It looks like an AfterSort event exists on some of the other platforms for the FlexGrid control. Does anything like that exist on the Xamarin FlexGrid control? I am trying to remove the row selection when sorting occurs.
    https://www.grapecity.com/en/blogs/maintain-row-selection-on-sorting-c1flexgrid
  • Posted 9 November 2017, 11:11 am EST
    You can use the SortChanged event of the FlexGrid’s CollectionView.
    http://help.grapecity.com/componentone/NetHelp/XamarinEdition/C1.CollectionView~C1.CollectionView.C1CollectionView`1_members.html
    First add the handler:
    ((C1CollectionView<object>)grid.CollectionView).SortChanged += GettingStarted_SortChanged;
    Then you’ll need to remove the selection when the event fires:
            private void GettingStarted_SortChanged(object sender, EventArgs e)
                grid.Select(new GridCellRange(-1, -1), false);
    The same pattern will hold true for other CollectionView derived behaviors like filtering and grouping.
    Kelley
  • Posted 9 November 2017, 11:22 am EST
    Works great - thank you very much! Good to know I can handle those CollectionView events like that. That will definitely be useful.
