FlexGrid crashes with Android
Posted by: software on 8 August 2017, 11:05 am EST
  • Posted 8 August 2017, 11:05 am EST
    [xuni_archive]I am using a FlexGrid Control in a XamarinForms Application. Everything went well when i run the iOS Version of the App. In Android however the App crashes.
    Is it possible that the different NuGet Packages Versions are the reason of that?
    PCL and iOs: 2.3.20171.189
    Android: 2.3.20171.185
    Volker
    [/xuni_archive]
    [xuni_archive]Hi Volker
    You should make sure that the version number matches between the Xuni.Forms.xxx, Xuni.iOS.xxx, and Xuni.Android. Otherwise you could run into some problems and experience some crashes.
    Kelley[/xuni_archive]
