Support for images in FlexGrid
Posted by: stefan on 4 June 2018, 2:12 am EST
  • Posted 4 June 2018, 2:12 am EST
    Is there any support for handling images in FlexGrid?
    I’m converting a .Net Compact Framework application where we use the ImageMap and ImageAndText properties on a column.
    We also use the SetCellImage function on the grid.
    I suppose I can implement this via custom cells, but if it is already possible or on the roadmap it would save me some time.
  • Posted 4 June 2018, 8:18 am EST
    You can use the Column’s CellTemplate to display images in FlexGrid:
    <c1:GridColumn Binding="OrderTotal" Header="Order Total" Width="*">
                    <c1:GridColumn.CellTemplate>
                        <DataTemplate>
                            <gauge:C1BulletGraph IsAnimated="False" IsReadOnly="True" Value="{Binding OrderTotal}" Min="0" Max="10000" Bad="1000" Good="6000" Target="7000"/>
                        </DataTemplate>
                    </c1:GridColumn.CellTemplate>
    </c1:GridColumn>
    Instead of C1BulletGraph, you can place an image control. Currently this is the only way to show images in FlexGrid.
  • Posted 4 June 2018, 9:15 am EST
    Hi Stefan
    Also, if you’ve downloaded our samples, you can take a look at the FlexGrid101 OnDemand sample and the GridImageColumn class it uses. You could borrow the code for the GridImageColumn, and use it for a similar solution in your project.
    https://github.com/GoXuni/C1-Studio-for-Xamarin/blob/master/XF/FlexGrid101/FlexGrid101.XF/View/OnDemand.xaml
    https://github.com/GoXuni/C1-Studio-for-Xamarin/blob/master/XF/FlexGrid101/FlexGrid101.XF/Columns/GridImageColumn.cs
    Kelley
  • Posted 4 June 2018, 12:50 pm EST
    Ok, thanks for the info. I’ll take a look at that.
