Autosearch in specific columns
Posted by: massimo.valtolina on 4 March 2020, 1:23 pm EST
    Posted 4 March 2020, 1:23 pm EST
    Good morning,
    is it possibile activate autosearch on specific columns ?
    Thanks in advance
    Massimo
  • Posted 5 March 2020, 2:35 am EST
    As per our understanding, you are using C1FlexGrid with AutoSearch property and there is no AutoSearch property at Column level so you need to handle it through BeforeRowColChange event to achieve the desired result as given in code snippet below:
    private void C1FlexGrid1_BeforeRowColChange(object sender, C1.Win.C1FlexGrid.RangeEventArgs e)
      if(e.NewRange.c1 == SpecificColumnIndex)
        c1FlexGrid1.AutoSearch = C1.Win.C1FlexGrid.AutoSearchEnum.FromTop;
      else
        c1FlexGrid1.AutoSearch = C1.Win.C1FlexGrid.AutoSearchEnum.None;
    Please go through the attached sample implementing the same.
    If you are using any other control then please let us know.
    AutoSearchDemo.zip
  • Posted 6 March 2020, 11:12 am EST
    Thanks a lot !
