C1StudioInstaller20181.1.17 offline installation and License activation
Posted by: bhaskara.chaithanya on 20 June 2018, 7:39 am EST
    Posted 20 June 2018, 7:39 am EST
    [b]Hi Team,
    We have got C1StudioInstaller20181.1.17.exe offline installer and serial number. Can you please let us know how many installations does this serial number permits.
    Chaithanya [/b]
  • Posted 21 June 2018, 12:09 am EST
    Hi Chaithanya,
    Licenses are per-developer. A developer may install his license on up to two machines (at one point of time). If you need to activate the key on a third machine, you would first need to deactivate it from any of the two earlier machines. Please refer the following link for more information on licensing:
    https://www.grapecity.com/en/licensing/componentone
    Let me know if you still have any questions.
    Pragati
  • Posted 25 June 2018, 4:22 am EST
    Hi Pragati,
    Thanks for the information.
    And if we want multiple installations. Do we get separate media for this?
    Can you please let us know if it is possible.
    Chaithanya
  • Posted 26 June 2018, 12:11 am EST
    Hi Chaithanya,
    If this is just about installation of the product , you can install it on ‘n’ number of machines using the same installer. And, your applications will run in evaluation mode (with nag screen).
    However, if your requirement is to activate the license on more than 2 machines, you would need to purchase additional licenses for the purpose.
    Please elaborate on your use case a bit further, if this is not what you are looking for.
    Pragati
  • Posted 26 June 2018, 5:40 am EST
    Hi Pragati,
    Yep I understood that we can install with the installer in n number of machines but we will be getting the pop-up to activate.
    So requesting that do we get any installer that can be used to install and activate in n number of machines.
    Thanks and Regards,
    Chaithanya :slight_smile:
  • Posted 27 June 2018, 4:23 am EST
    Hi Chaithanya,
    Activating license on a machine does not actually depend on the installer. It is about the license key being activated on the machine. Since your requirement is to activate the license on more machines at your end, please purchase the required number of licenses. You can contact our sales team for the purpose:
    https://www.grapecity.com/en/contact
    Pragati
