C1StudioInstaller20181.1.17 offline installation error
Posted by: nikolai.chmatov on 11 July 2018, 3:13 pm EST
    Posted 11 July 2018, 3:13 pm EST - Updated 4 October 2022, 8:14 am EST
    Hi Support team,
    I’ve error during installation, here is the case:
    • Installation procedure started and allow me to select components to install
    • By Clicking on NEXT I’ve got an error message:
      Error
      The Resource could not be found
      Interop.SHDocVw.dll
      but DLL is sitting in C:\WINNT\System32
    Nikolai
  • Posted 12 July 2018, 5:09 am EST
    Please try the 2018v1 offline installer and see if the issue still persists. You may access the installer from here: http://cdn.componentone.com/files/studioinstaller/C1StudioInstaller20181.1.17.exe
    If somehow the issue still persists, could you please attach the C1StudioInstaller.log file created in your Documents folder, so that we investigate accordingly and share the details with the installer team, if needed.
    Ruchir
  • Posted 12 July 2018, 12:09 pm EST
    Hi Ruchir,
    I’ve checked log and found the reason:
    during installation, installer attempting to extract
    GrapeCity.Installers.C1StudiosWebInstaller.dll.Interop.SHDocVw.dll
    to <> with Result=“false”
    because “Access to the path is denied.”
    …any suggestions (except remove protection :wink: ?
    Nikolai
  • Posted 13 July 2018, 7:13 am EST
    Hi Nikolai,
    We have created a case over for you our portal https://supportone.componentone.com/casedetail/334119 and have responded you over there.
    Also, request you to continue further discussions over there.
    Ruchir
