C1StudiosWebInstaller has stopped working
Posted by: jordan.gower on 1 December 2017, 4:44 am EST
    Posted 1 December 2017, 4:44 am EST
    I am trying to install trial version for one of our users, downloaded the installer and run on my admin account but as soon as the installer starts it fails and get error message.
    I also get this on my own PC as well.
    running win 7 64bit
    have attached the log file.
    jordan
  • Posted 4 December 2017, 12:23 am EST
    Hello Jordan,
    The log file seems to be missing. Kindly try to attach it again in zip format.
    Also, can you share the version of the installer that you have downloaded along with the error message that you receive? This will help us assist you further.
  • Posted 12 December 2017, 11:20 am EST
    Hi
    I have the same issue when running C1StudiosWebInstaller where it stops responding, attached is the log file. Option wise within the installer I am selecting ASP.NET MVC only running as Admin.
    Installer version is: C1StudiosWebInstallerv20173.1.8.exe
    Error message is: ‘C1StudiosWebInstaller has stopped working’.
    Iain
    C1StudiosWebInstaller.zip
  • Posted 13 December 2017, 3:22 am EST
    Please try using the offline installer below and let us know if the issue is resolved for you:
    http://cdn.componentone.com/files/studioinstaller/C1StudioInstaller20173.1.9.exe
  • Posted 13 December 2017, 5:04 am EST
    Great, that worked! Thanks for your help.
  • Posted 19 January 2018, 5:31 am EST
    Hello
    I tried installing the ComponentOne with the link that you had provided but i still get the error message ‘C1StudiosWebInstaller has stopped working’.
  • Posted 22 January 2018, 12:31 am EST
    Hello Niru,
    Did you try using the offline installer from the below mentioned link?
    If yes, please share the log file created in your [User Documents] folder. This would help us in investigating the problem further.
  • Posted 22 January 2018, 3:04 am EST
    Hello Esha,
    I tried installing the application from the installer in the above mentioned link as well but still the error is persistent. Here’s the event log file information:
    Faulting application name: C1StudioInstaller20173.1.9(1).exe, version: 2017.3.1.9, time stamp: 0x5a093ecd
    Faulting module name: KERNELBASE.dll, version: 6.1.7601.23915, time stamp: 0x59b94abb
    Exception code: 0xe0434f4d
    Fault offset: 0x0000c54f
    Faulting process id: 0x%9
    Faulting application start time: 0x%10
    Faulting application path: %11
    Faulting module path: %12
    Report Id: %13
  • Posted 22 January 2018, 5:35 am EST
    Hello Niru,
    We would need the complete log file to be able to escalate the issue to the concerned team. Kindly share the same along with the system environment details, so that we can assist you at the earliest.
  • Posted 23 January 2018, 12:45 am EST
    Hello Esha,
    Thank you for your assistance. I am able to install componentOne in my machine.
