Posted 27 March 2019, 4:49 am EST
The version is C1.Web.Wijmo.Controls.C1GridView 4.0.20172.264. I agree that it supports itemTemplate and EditItemTemplate. If you notice the attached screenshot, you will see how I used EditItemplate column. I created a table for EditTemplate and when the use clicks on the itemTemplate column it shows up for user input,not just the column it binds to the itemtemplate but some other transient fields. The save or cancel inside the EditTemplate take the action to save to the database through custom methods or cancel the edit action.
In version 4.0.20172.264, I tried to do the same by defining the column in ItemTemplate as a link button and a small table of all the columns in the grid for data entry in EditItemTemplate. However, when I click on the link button, the grid refreshes but the column does not go into edit mode.
The example in the demo is to use a commandcolumn with Edit/Udate/Cancel and that edits the entire row when I click on Edit button. However, I want to be able to keep the functionality of how I used the EditTemplate in previous version (VS 2003). I am just trying to understand why when I click on the linkbutton defined in ItemTemplate field does not trigger any event and does not show the table defined in the EditTemplate field.
Thanks for your quick response.
